FW: Problem running reports using Crystal Enterprise
The Crystal Management Console is only available through Crystal Enterprise as far as I'm aware. Actually, you might have the Crystal Enterprise disk with your CR Pro 8.5 software. The company that I worked for received Crystal Enterprise for free as a separate disk when they bought CR Pro 8.5. The disk was in the same packaging as CR Pro. I believe that Crystal Enterprise was intended to replace report executables that are put on user's workstations. Crystal Enterprise is integrated with IIS (or some other options) to be used as a report distribution tool. It uses your web browser to access the reports. It's a pretty cool tool!
As far as I'm aware, CR Pro does not have the feature to allow for "saving of the db password" when a user needs to access a report. The password is needed locally to pass the db information through ODBC. Crystal Enterprise, on the other hand, allows for storing of the password on the report level so that way the user does not need to enter it in (normally).
~Wendy
>>> joeyloken@... 07/15/03 12:23PM >>>
Is the Crystal Report Management Console only available on the
server?? We are using CR Pro 8.5 for Epicor. Does it have this
feature? I am looking for a place to enter the db password so the
user doesn't have to enter it each time they run a report...
--- In vantage@yahoogroups.com, "Dan Tisone" <dtisone@b...> wrote:
> It's under the Crystal Management Console, Global Management
Settings.
> I see what you are talking about but the data is view only, not
> editable. Right now I am passing the credentials along with the
report
> to the Crystal Server like so:
> http://PriceList.rpt?user0=odbcuser&password0=odbcuser
> If you guys found a way to hard code these credentials into the
Crystal
> Configuration, let me know because it would solve my sub-report
> credential problem.
> Wendy - When you get a chance to check it, would you contact me
> off-group?
> Dan Tisone
> Operations / IT Consultant
> dan.tisone@b...
> -----Original Message-----
> From: WENDY BOWEN [mailto:WENDY.BOWEN@c...]
> Sent: Monday, July 14, 2003 1:54 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] FW: Problem running reports using Crystal
> Enterprise
> The standard version. I would like to use the Pro version, but I
know
> it's very pricey.
> It's under Enterprise's Report Configuration menu. There is a
database
> tab that gives you these options. I don't have Enterprise up, but I
> believe the tab is called "Database". Someone please correct me if
I'm
> wrong.
> ~Wendy
> >>> dtisone@b... 07/14/03 04:43PM >>>
> Are you folks talking about the Standard version or Professional
> version?? I have the Standard version and do not see some of the
items
> Dan Tisone
> dan.tisone@b...
> Sent: Monday, July 14, 2003 12:32 PM
> Enterprise
> Mary,
> I don't have Enterprise up right now, but do you have a "Database"
tab?
> If I remember correctly there is a "database" tab under the
Enterprise
> Report configuration that needs to have the report username and
password
> entered.
> ~Wendy
> >>> mhorsey@g... 07/14/03 03:18PM >>>
> Wendy,
> Yes, we have entered the username and password for the report in the
> properties portion under INSTANCES. The status report
showed "Cannot
> open SQL server", no other details were provided.
> Mary
> Sent: Monday, July 14, 2003 1:57 PM
> Subject: Re: [Vantage] FW: Problem running reports using Crystal
> Enterprise
> Mary, dumb question, but did you set the report's settings in the
> Enterprise Report Configuration Manager? Also, in this area it
allows
> you to set the password of the database for the report so that way
you
> don't have to "login" each time you run the report. If you find
that the
> login prompt reappears over and over again, I know that Seagate has
a
> patch for that.
> ~Wendy
> >>> mhorsey@g... 07/14/03 01:47PM >>>
> We have recently installed a Crystal Enterprise web server and
loaded a
> few test reports on it. It seems that we have a problem connecting
the
> report to the Progress (9.1D) server when trying to run the
reports. The
> left site of the screen flashed "Loading" very quickly after we
provided
> the login information to the database, and the login prompt
reappears.
> In ODBC control panel, we were able to test a connection
successfully.
> Is there a special procedure for connecting Crystal Enterprise to
the
> Progress database?
> Thanks in advance for your input.
> Mary Horsey
> Greene Rubber Company
> 20 Cross Street
> Woburn MA 01801
> 781-497-1851 (phone)
> 781-937-9739 (fax)
> Yahoo! Groups Sponsor
> ADVERTISEMENT
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
must
access. )
Builder
> http://docs.yahoo.com/info/terms/
> ADVERTISEMENT
must
access. )
Builder
Service.
must
access. )
Builder
> ADVERTISEMENT
must
access. )
Builder
Service.
must
access. )
Builder
ADVERTISEMENT
We have recently installed a Crystal Enterprise web server and loaded a few
test reports on it. It seems that we have a problem connecting the report
to the Progress (9.1D) server when trying to run the reports. The left site
of the screen flashed "Loading" very quickly after we provided the login
information to the database, and the login prompt reappears.
In ODBC control panel, we were able to test a connection successfully. Is
there a special procedure for connecting Crystal Enterprise to the Progress
database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
Mary, dumb question, but did you set the report's settings in the Enterprise Report Configuration Manager? Also, in this area it allows you to set the password of the database for the report so that way you don't have to "login" each time you run the report. If you find that the login prompt reappears over and over again, I know that Seagate has a patch for that.
~Wendy
>>> mhorsey@... 07/14/03 01:47PM >>>
database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
Wendy,
properties portion under INSTANCES. The status report showed "Cannot open
Mary
Enterprise
~Wendy
database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
Mary,
I don't have Enterprise up right now, but do you have a "Database" tab? If I remember correctly there is a "database" tab under the Enterprise Report configuration that needs to have the report username and password entered.
~Wendy
>>> mhorsey@... 07/14/03 03:18PM >>>
Wendy,
Mary
Enterprise
~Wendy
database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
ADVERTISEMENT
version?? I have the Standard version and do not see some of the items
Dan Tisone
dan.tisone@...
Enterprise
Mary,
entered.
~Wendy
Wendy,
Mary
Enterprise
patch for that.
~Wendy
few test reports on it. It seems that we have a problem connecting the
report to the Progress (9.1D) server when trying to run the reports.
The left site of the screen flashed "Loading" very quickly after we
provided the login information to the database, and the login prompt
reappears.
Is
Progress database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
ADVERTISEMENT
The standard version. I would like to use the Pro version, but I know it's very pricey.
It's under Enterprise's Report Configuration menu. There is a database tab that gives you these options. I don't have Enterprise up, but I believe the tab is called "Database". Someone please correct me if I'm wrong.
~Wendy
>>> dtisone@... 07/14/03 04:43PM >>>
Dan Tisone
dan.tisone@...
Enterprise
Mary,
entered.
~Wendy
Wendy,
Mary
Enterprise
patch for that.
~Wendy
reappears.
Is
Progress database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
It's under the Crystal Management Console, Global Management Settings.
editable. Right now I am passing the credentials along with the report
If you guys found a way to hard code these credentials into the Crystal
credential problem.
off-group?
Dan Tisone
dan.tisone@...
Enterprise
it's very pricey.
wrong.
~Wendy
Dan Tisone
dan.tisone@...
Enterprise
Mary,
entered.
~Wendy
Wendy,
Mary
Enterprise
patch for that.
~Wendy
report to the Progress (9.1D) server when trying to run the reports. The
left site of the screen flashed "Loading" very quickly after we provided
the login information to the database, and the login prompt reappears.
Is there a special procedure for connecting Crystal Enterprise to the
Progress database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Mary,
This may have went away since I last used CE, but I had to make sure
that each of the Crystal Enterprise services (Control Panel,
Administrative Tools, Services) were running as Administrator, not
SystemAccount, before I could get rid of the looping database login. Do
you think that might be the problem?
Adam Ellis
Senior Consultant - SaberLogic, LLC
661-B Weber Dr.
Wadsworth, OH 44281
Phone: (330) 335-6442
Cell: (330) 697-3883
www.saberlogic.com
> database?
Mary,
We are using CE for our web server for Crystal reports. I have never
been able to run Progress reports using the Crystal Management Console. I
get the same error you get. I was hoping to use the console to schedule
reports. I had a call logged into Crystal Support (issue 1361991) back when
I had free support, but they never resolved the issue after trying umpteen
different things.
I have settled for using simple URL links to run reports, adding them to
people's favorites in Internet Explorer. For scheduling reports I use a
nifty program the Adam Ellis wrote and made available to the group. It has
worked flawlessly for over a year now.
It would be nice if someone tackled the issue with Seagate and let us all
know what's up.
Troy Funte
Liberty Electronics
Sent: Monday, July 14, 2003 1:47 PM
Subject: [Vantage] FW: Problem running reports using Crystal Enterprise
few
site
Is
Progress
database?
Mary Horsey
20 Cross Street
Woburn MA 01801
781-937-9739 (fax)
ADVERTISEMENT
Settings.
report
Crystal
> credential problem.
> off-group?
> Dan Tisone
> dan.tisone@b...
> Enterprise
know
> it's very pricey.
database
I'm
> wrong.
> ~Wendy
items
> Dan Tisone
> dan.tisone@b...
> Enterprise
> Mary,
tab?
Enterprise
password
> entered.
> ~Wendy
> Wendy,
showed "Cannot
> Mary
> Enterprise
allows
you
that the
a
> patch for that.
> ~Wendy
loaded a
the
reports. The
provided
reappears.
successfully.
the
> Progress database?
> Mary Horsey
> 20 Cross Street
> Woburn MA 01801
> 781-937-9739 (fax)
> ADVERTISEMENT
must
access. )
Builder
must
access. )
Builder
> ADVERTISEMENT
must
access. )
Builder
Service.
must
access. )
Builder
> ADVERTISEMENT
must
access. )
Builder
Service.
must
access. )
Builder
