Thanks for the tip, Todd-this may solve a little problem here, too.
Lydia
Sent: Wednesday, July 18, 2001 8:22 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] FW: Production Calendar problem
Jim,
Under "Database Conversions" on your system menu. Look for "Build Shop Load
File" and run it. Make sure no one is in "Visual scheduling". This
typically takes 2-8 minutes to run and will scratch your shop load file and
rebuild it.
I've been running this utility on a regular basis from the dawn of creation.
Under V3 I ran it about once a week and under V4 about once a month. V4 is
much better at keeping the load file correct while V3 was noted for having
ghost images in the load file.
Best explanation I received was that when jobs are closed or other changes
are made not ALL of the Vantage programs update the shop load file correctly
so a periodic rebuild sometimes does wonders.
Good Luck,
Todd Anderson
Sent: Wednesday, July 18, 2001 10:11 AM
Cc: Sven Bley
Subject: [Vantage] FW: Production Calendar problem
Hello,
Now, after looking at my shop load reports, I have discovered that my
information is being saved. The problem is there is no visual display of
the changes on the Production Calendar. Meaning, days that have less hours
scheduled than the normal capacity, do not turn the color blue. In
addition, holidays do not turn color to white. This must be a technical
issue, but if it is not, please let me know. Any help would be greatly
appreciated.
Jim Selinger
Production Scheduler
Bley Engineering Co.
Elk Grove Village, IL
jselinger@...
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
To access the Files Section of our Yahoo!Group for Report Builder and
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
Lydia
Jim,
rebuild it.
Good Luck,
Todd Anderson
Cc: Sven Bley
Hello,
appreciated.
Jim Selinger
jselinger@...
> -----Original Message-----To access the Files Section of our Yahoo!Group for Report Builder and
> From: Selinger, Jim
> Sent: Tuesday, July 17, 2001 1:29 PM
> Subject: Production Calendar problem
> Hello all,
> I am struggling with an issue in using the Production calendar. (we are
> still using version 3.0) I can not save any changes I make to it. I will
> add in a holiday, or a Saturday, and I come back, and none of my changes
> are saved. I recently broke up most of our machines into their own work
> centers, to make scheduling easier and the loads more accurate. Could
> that have caused a problem? Changes will not save in either a custom or
> the plant calendar. Is this a technical issue? Please help.
> Jim Selinger
