FW: Reports - No Records Selected
In case anyone starts using the status balloons and gets frustrated because the times disappear in Task History tab... SCR94566 is targeted for 701 to fix this.
As a workaround, uncheck the options if you need to see what was running at a specific time and can't find it in the list before the screen refreshes :)
--- In vantage@yahoogroups.com, "Jeff Greenaway" wrote:
Hello All,
Found something new and want to share. At least it's new to me but has apparently been around since 9.05.604. Â A regular complaint I hear from clients is when you run a report, sometimes it doesn't appear, and you have to dig into System Monitor to find out it was a "No Records Selected".
Here's how to get notified when that happens:
1. Open System Monitor (i.e. "blue hamburger").
2. Go to Actions, then Status Balloon Properties.
3. Click on "Popup on Report Errors".
4. Now when you run a report that has "No Records Selected" (or any other error) you will see a popup box in the lower right of your screen. It looks similar to an Outlook notification.
Of course, you can also set it to notify you when reports are successful or processes are or are not successful.
Hopefully others will find this useful too.
Hello All,
Found something new and want to share. At least itÂ’s new to me but has
clients is when you run a report, sometimes it doesnÂ’t appear, and you have
to dig into System Monitor to find out it was a “No Records Selected”.
HereÂ’s how to get notified when that happens:
1. Open System Monitor (i.e. “blue hamburger”).
3. Click on “Popup on Report Errors”.
4. Now when you run a report that has “No Records Selected” (or any other
Regards,
Jeff
Jeff Greenaway
Owner/Consulting CIO
CIO onDemand
www.CIO-onDemand.com
Great share Jeff, didnt know about it! I just tried it and it worked
Â
Thanks again
Sent: Sunday, July 1, 2012 11:54 AM
Subject: [Vantage] FW: Reports - No Records Selected
Â
Hello All,
Found something new and want to share. At least it’s new to me but has
clients is when you run a report, sometimes it doesn’t appear, and you have
Here’s how to get notified when that happens:
Regards,
Jeff
Jeff Greenaway
CIO onDemand
http://www.cio-ondemand.com/
If I remember correctly the user has to have configuration rights to select the checkbox. Configuration rights can be removed one the box is checked.
Sent from my iPad
> Thanks again
> From: Jeff Greenaway <vantagegroup@...>
> Hello All,
> apparently been around since 9.05.604. A regular complaint I hear from
> Regards,
> Jeff
> Jeff Greenaway
> CIO onDemand
Is there anyway this can be done in 8.03.409C?
