FW: Screen hangs
You may be seeing the Intel PROMON utility that manages their NICs, if in
fact you're using their cards. I was thrown by this one for a moment!
John Hannaford
Corp. IS/T Mgr.
Precision Resource
Sent: Friday, April 27, 2001 12:23 PM
To: vantage@yahoogroups.com; vantage@yahoogroups.com
Subject: Re:RE: [Vantage] FW: Screen hangs
I've noticed the same thing on our network. I also noticed that when I
press
Ctrl-Alt-Del that PROMON is running! It's not on one workstation but on
all.
When I stop PROMON the "hangs" are no longer a problem.
I have not been able to see how or why PROMON is loading on each and every
workstation. Any ideas would be greatly appreciated.
BTW, I've re-booted our server several times (for other reasons) and the
problem
has not gone away.
Mike Lowe
Connor
____________________Reply Separator____________________
Subject: RE: [Vantage] FW: Screen hangs
Author: <vantage@yahoogroups.com>
Date: 4/27/2001 8:30 AM
We just installed patch 904 for Version 4.0 two weeks ago. The week
following we also started experiencing screen hangs, at first it was just
one or two stations, but now it has spread to almost every workstation.
Some freeze the workstation and require a re-boot to get going again, while
other times we can do an Alt-Ctrl-Delete and end the task (we are using NT
4).
I talked with Vantage support; one person told me I should have put patch 44
on for progress 9.0 as well. I talked to support a second time and the 2nd
tech said I just needed to re-boot our server.
I intend to do both this weekend.
Anyone one else have any suggestions?????????
Warren R. Eddy
Information Services Manager
National Tube Form, LLC
Phone: (219) 478-2363 ext 217
Fax: (219) 478-1043
Warren.Eddy@...
Sent: Friday, April 27, 2001 6:55 AM
Subject: [Vantage] FW: Screen hangs
Sent: 27 April 2001 10:34
To: vanateg@yahoogroups.com
Subject: Screen hangs
We are experiencing screen hangs lasting 10 seconds to a few minutes on
different workstations and on different areas of Vantage. It is only Vantage
that has hung all other operating systems on the workstations are ok. Has
anyone experienced this and were they able to resolve it.
Regards
Ian Chawtin
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Crystal
Received: from mv.egroups.com [208.50.144.81] by cfmp.com (ccMail Link to
SMTP R8.31.00.5)
; Fri, 27 Apr 2001 06:34:05 -0700
Return-Path:
<sentto-20369-20617-988378418-MLowe=CFMP.COM@...>
X-eGroups-Return:
Received: from [10.1.4.52] by mv.egroups.com with NNFMP; 27 Apr 2001
13:33:38 -0000
X-Sender: Warren.Eddy@...
X-Apparently-To: vantage@yahoogroups.com
Received: (EGP: mail-7_1_2); 27 Apr 2001 13:33:37 -0000
Received: (qmail 39824 invoked from network); 27 Apr 2001 13:30:53 -0000
Received: from unknown (10.1.10.26) by m8.onelist.org with QMQP; 27 Apr 2001
13:30:53 -0000
Received: from unknown (HELO etcstlntex.excalibercorp.com) (206.230.36.5) by
mta1 with SMTP; 27 Apr 2001 13:30:53 -0000
Received: by ETCSTLNTEX with Internet Mail Service (5.5.2650.21) id
<JKLWMYJR>; Fri, 27 Apr 2001 08:30:22 -0500
Message-ID: <F7DDB6798761D411A90700D0B789B09F51AE94@ETCSTLNTEX>
To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
X-Mailer: Internet Mail Service (5.5.2650.21)
MIME-Version: 1.0
Mailing-List: list vantage@yahoogroups.com; contact
vantage-owner@yahoogroups.com
Delivered-To: mailing list vantage@yahoogroups.com
Precedence: bulk
List-Unsubscribe: <mailto:vantage-unsubscribe@yahoogroups.com>
Date: Fri, 27 Apr 2001 08:30:19 -0500
Reply-To: vantage@yahoogroups.com
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
I've noticed the same thing on our network. I also noticed that when I press
Ctrl-Alt-Del that PROMON is running! It's not on one workstation but on all.
BTW, I've re-booted our server several times (for other reasons) and the problem
has not gone away.
Mike Lowe
Connor
4).
Warren R. Eddy
Fax: (219) 478-1043
Warren.Eddy@...
Regards
Ian Chawtin
To access the Files Section of our Yahoo!Group for Report Builder and Crystal
Received: from mv.egroups.com [208.50.144.81] by cfmp.com (ccMail Link to SMTP R8.31.00.5)
Return-Path: <sentto-20369-20617-988378418-MLowe=CFMP.COM@...>
X-eGroups-Return: sentto-20369-20617-988378418-MLowe=CFMP.COM@...
Received: from [10.1.4.52] by mv.egroups.com with NNFMP; 27 Apr 2001 13:33:38 -0000
Received: from unknown (10.1.10.26) by m8.onelist.org with QMQP; 27 Apr 2001 13:30:53 -0000
Received: from unknown (HELO etcstlntex.excalibercorp.com) (206.230.36.5) by mta1 with SMTP; 27 Apr 2001 13:30:53 -0000
Received: by ETCSTLNTEX with Internet Mail Service (5.5.2650.21) id <JKLWMYJR>; Fri, 27 Apr 2001 08:30:22 -0500
MIME-Version: 1.0
Mailing-List: list vantage@yahoogroups.com; contact vantage-owner@yahoogroups.com
Precedence: bulk
