Thanks John, that explains the presence of PROMON. Now if I can only figure out
why the clients keep hanging...
Thanks!
Mike Lowe
Connor
____________________Reply Separator____________________
Subject: RE: RE: [Vantage] FW: Screen hangs
Author: <
vantage@yahoogroups.com>
Date: 4/30/2001 12:05 PM
You may be seeing the Intel PROMON utility that manages their NICs, if in
fact you're using their cards. I was thrown by this one for a moment!
John Hannaford
Corp. IS/T Mgr.
Precision Resource
MLowe@...]
Sent: Friday, April 27, 2001 12:23 PM
To:
vantage@yahoogroups.com;
Subject: Re:RE: [Vantage] FW: Screen hangs
I've noticed the same thing on our network. I also noticed that when I
press
Ctrl-Alt-Del that PROMON is running! It's not on one workstation but on
all.
When I stop PROMON the "hangs" are no longer a problem.
I have not been able to see how or why PROMON is loading on each and every
workstation. Any ideas would be greatly appreciated.
BTW, I've re-booted our server several times (for other reasons) and the
problem
has not gone away.
Mike Lowe
Connor
Subject: RE: [Vantage] FW: Screen hangs
Author: <
Date: 4/27/2001 8:30 AM
We just installed patch 904 for Version 4.0 two weeks ago. The week
following we also started experiencing screen hangs, at first it was just
one or two stations, but now it has spread to almost every workstation.
Some freeze the workstation and require a re-boot to get going again, while
other times we can do an Alt-Ctrl-Delete and end the task (we are using NT
4).
I talked with Vantage support; one person told me I should have put patch 44
on for progress 9.0 as well. I talked to support a second time and the 2nd
tech said I just needed to re-boot our server.
I intend to do both this weekend.
Anyone one else have any suggestions?????????
Warren R. Eddy
Information Services Manager
National Tube Form, LLC
Phone: (219) 478-2363 ext 217
Fax: (219) 478-1043
Warren.Eddy@...
ian@...]
Sent: Friday, April 27, 2001 6:55 AM
To:
Subject: [Vantage] FW: Screen hangs
ian@...]
Sent: 27 April 2001 10:34
To:
vanateg@yahoogroups.com
Subject: Screen hangs
We are experiencing screen hangs lasting 10 seconds to a few minutes on
different workstations and on different areas of Vantage. It is only Vantage
that has hung all other operating systems on the workstations are ok. Has
anyone experienced this and were they able to resolve it.
Regards
Ian Chawtin
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Crystal
Received: from mv.egroups.com [208.50.144.81] by cfmp.com (ccMail Link to
SMTP R8.31.00.5)
; Fri, 27 Apr 2001 06:34:05 -0700
Return-Path:
<sentto-20369-20617-988378418-MLowe=
CFMP.COM@...>
X-eGroups-Return:
CFMP.COM@...
Received: from [10.1.4.52] by mv.egroups.com with NNFMP; 27 Apr 2001
13:33:38 -0000
X-Sender:
Warren.Eddy@...
X-Apparently-To:
Received: (EGP: mail-7_1_2); 27 Apr 2001 13:33:37 -0000
Received: (qmail 39824 invoked from network); 27 Apr 2001 13:30:53 -0000
Received: from unknown (10.1.10.26) by m8.onelist.org with QMQP; 27 Apr 2001
13:30:53 -0000
Received: from unknown (HELO etcstlntex.excalibercorp.com) (206.230.36.5) by
mta1 with SMTP; 27 Apr 2001 13:30:53 -0000
Received: by ETCSTLNTEX with Internet Mail Service (5.5.2650.21) id
<JKLWMYJR>; Fri, 27 Apr 2001 08:30:22 -0500
Message-ID: <F7DDB6798761D411A90700D0B789B09F51AE94@ETCSTLNTEX>
To: "'
vantage@yahoogroups.com'" <
X-Mailer: Internet Mail Service (5.5.2650.21)
warren.eddy@...>
MIME-Version: 1.0
Mailing-List: list
vantage@yahoogroups.com; contact
vantage-owner@yahoogroups.com
Delivered-To: mailing list
Precedence: bulk
List-Unsubscribe: <mailto:
vantage-unsubscribe@yahoogroups.com>
Date: Fri, 27 Apr 2001 08:30:19 -0500
Reply-To:
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
To access the Files Section of our Yahoo!Group for Report Builder and Crystal
Received: from fj.egroups.com [64.211.240.231] by cfmp.com (ccMail Link to SMTP R8.31.00.5)
; Mon, 30 Apr 2001 09:04:48 -0700
Return-Path: <sentto-20369-20654-988646714-MLowe=
CFMP.COM@...>
X-eGroups-Return: sentto-20369-20654-988646714-MLowe=
CFMP.COM@...
Received: from [10.1.4.56] by fj.egroups.com with NNFMP; 30 Apr 2001 16:05:14 -0000
X-Sender:
johnh@...
X-Apparently-To:
Received: (EGP: mail-7_1_2); 30 Apr 2001 16:05:13 -0000
Received: (qmail 39058 invoked from network); 30 Apr 2001 16:05:12 -0000
Received: from unknown (10.1.10.142) by l10.egroups.com with QMQP; 30 Apr 2001 16:05:12 -0000
Received: from unknown (HELO prcn05.localdomain.com) (209.121.182.2) by mta3 with SMTP; 30 Apr 2001 16:05:11 -0000
Received: From PRCN01.PR-CN.COM (192.168.0.98[192.168.0.98 port:4071]) by prcn05.localdomain.com Mail essentials (server 2.422) with SMTP id: <
2049@...> for <
vantage@yahoogroups.com>; Mon, 30 Apr 2001 12:04:30 PM -0400 smtpmailfrom <
johnh@...>
Received: by PRCN01 with Internet Mail Service (5.5.2653.19) id <JCCNAKZZ>; Mon, 30 Apr 2001 12:05:51 -0400
Message-ID: <BB5C274EAFAAD111962800A0C99DB6F76F966E@PRCN01>
To:
X-Mailer: Internet Mail Service (5.5.2653.19)
johnh@...>
MIME-Version: 1.0
Mailing-List: list
Precedence: bulk
Date: Mon, 30 Apr 2001 12:05:48 -0400
Reply-To:
