FW: Service Contract header date changes back to todays system da te
Ditto...
Regards,
Scott
Sent: Thursday, April 14, 2005 6:12 PM
To: sal@...
Subject: Call Number 1225248MPS Technical Support Reply: FM: Service
Contract header date changes back to todays system date
Please reference call # 1225248MPS if you have any additional questions
on this issue.
Scott:
This issue with the Service Contract Header date was submitted on the
page 14403MPS enclosed below and has been acknowledged as a bug by our
development staff and will be tracked by SCR 21884, attached to the
page. You will be notified via an automatic email when it is fixed.
This support call will be closed, but the SCR will remain open in
development until it is fixed. See the document below for details and a
work around, if applicable.
Please refer to the above call number or to the SCR number when
calling back to inquire on status.
At this point, we do not yet have a fix timeframe for the issue.
Thank you for pointing out this problem.
Let me know if you have any further questions or comments on this
issue.
Thank you in advance for not responding to this email. Email is not
monitored and could delay service on support issues. You will need to
contact the support center by one of the following 3 methods:
1) Calling our support line at 800-269-3044 for Vantage and 800-483-4049
for Vista.
2) 2) Over the internet at vantage.res@..., or thru ePortal
<http://eportal.epicor.com>
at our website at http://www.epicor.com
3) By fax at 952-582-5568
Phil Berglund
PAGE 14403MPS
PROBLEM DESCRIPTION:
Service Contract Header Entered date changes back to system date.
PROGRAM ID: FS/FSE10-hd.w
SOFTWARE AND DATABASE INFO: Vantage 6.10.521 on MNTECH
STEPS TO DUPLICATE:
1. FS > GO > Service Contract Entry.
2. Contract > Add Contract to the Service contract header screen.
3. The Entered date defaults to today's date / System Date.
4. Change it to a different date, say a few days in the past.
5. Select a vendor in the Sold To and click OK to save.
6. Click contract > Update Contract back to this screen.
7. The Entered Date has incorrectly changed back to today's date /
System Date. It should retain the date you change it to above.
8. Or if it is meant to always stay with the System Date from when a
user enters it, then it should be dimmed out and not available for
change.
9. See this on MNTECH 6.10.521, Vantage, Service Contract 154. Or
with any other new one that is added.
VERSION NUMBER: 6.10.521
ADDITIONAL INFO:
RESPONSE FROM PROGRAMMING:
SCR 21884
Since at least Vantage 5.00, the Service Contract Header Maintenance
program (fs/fse10-hd.w) has not let a user change the entry date since
that is the date when the contract was entered into the computer. But
the field is enabled, leading users to think that they can change it.
The field needs to be disabled since it is not user-maintainable.
