That's true, and at that point your costs should match the costs that you
had in Classic. Isn't that what you wanted?
Kathleen
Sent: Tuesday, September 12, 2000 5:21 AM
To: vantage@egroups.com
Subject: Re: [Vantage] Fw: standard cost
The boxes are pull as and view as assembly. When left unchecked, they
appear as material.
Kathleen
appear as material.
----- Original Message -----
To: <vantage@egroups.com>
Sent: Monday, September 11, 2000 8:08 PM
Subject: RE: [Vantage] Fw: standard cost
> I confused. You say below that your "components are set up in the BOM as
> material, both pull as and view as."
> Kathleen
> From: Monica [mailto:msmlycro@...]
> Sent: Monday, September 11, 2000 5:07 AM
> Kathleen, we don't have any boxes checked. The problem must be something
> else.
> From: Kathleen Harrington <kharrington@...>
> Sent: Friday, September 08, 2000 11:34 AM
> > Uncheck the Pull As box and it will treat the assembly as material.
> > Kathleen Harrington
> > Plant Accountant & Cost Accountant
> > SPS Non-Ferrous
> > Sent: Friday, September 08, 2000 9:23 AM
> > Subject: [Vantage] Fw: standard cost
> > I have a question in which I hope someone can help.
> > We are currently loading part masters and BOMs into Vantage 4.0 from
> > Classic. Since most of our business is repetitive, we are building
> > everything to stock and shipping from stock. When doing a cost roll up,
I
> > noticed something different pertaining to standard costs for assemblies
> when
> > comparing costs from Vantage to Classic. The component costs matched
> fine.
> > However the assembly cost was divided out differently between material,
> > labor and burden. Here is an example:
> > Part No. 78-8130, assembly
> > Material Labor Burden
Total
> > Classic: 5.1442 .3846 .6284
6.1572
> > Vantage: 3.97307 .79944 1.38536 6.15787
> > This part consists of 2 components with the following costs:
> Total
> > 78-8140 3.19397 .34667 .64853
4.18917
> > 78-8150 .77910 .06797 .10823
> .95530
> > The operations for the assembly include welding and drilling. The
> > components are set up in BOM as material, both pull as and view as. Can
> > anyone help me understand why these are different? If you need more
> > information, please let me know. Thanks!
> > Monica Miller
> > Lycro Products Co., Inc.
> > We no longer allow attachments to files. To access/share Report Files,
> > please go to the following link: http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try it, go
> to
> > www.egroups.com, login and be sure to save your password, choose My
> Groups,
> > choose Vantage, then choose Files. If you save the password, the link
> above
> > will work the next time you try it.)
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
to
Groups,
above
