FY change Blank Title 104996
Hi,
Just giving this FY change message a bump.
I'm still looking for any advice or comments you can give on a fiscal year change.
So far I've been looking at the following two general solutions.
1 - One short fiscal year
- Close the current FY (2012, all 12 periods)
- start a new FY (also 2012 but has fewer periods)
- Increase periods to 12 for the new FY - 2013
2 - One long fiscal year
- Increase the number of periods (17 in this case)
- closed out all income statement accounts to RE, accumulating info for the short year(8/1/2012 to 12/31/2112 in this case)
- Reduce the number of periods to 12 for FY 2013
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> Hi,
> I'm looking for advice on making a Fiscal Year change.
> Current = 8/01/XXXX to 7/31/XXXX
> Future = 01/01/XXXX to 12/31/XXXX
> The Company GL setup looks like this now:
> - Number of Periods = 12
> - Year = 2012
> - Period = 3
> It looks like the easiest approach would be to add 5 periods to FY 2012 so that it ends in 12/31/2012? Then start FY 2013 with 12 periods?
> Is there any (easy) way to make 2012 a short year?
> 5 periods and end 12/31/2011?
> If a new year begins on 01/01/2012... the year 2012 has already been used.
> Thanks
Hi,
- Year = 2012
- Period = 3
How about history transactions - fiscal month and year update.
It will require hitting all files with fiscal month and year.
What version are you running? SQL or Progress?
Sent from my iPhone
1-734-812-9532 - cell#
Carl Peterson
On Oct 26, 2011, at 3:50 PM, "cooner_55421" <cooner_55421@...> wrote:
> Hi,
> - Year = 2012
> - Period = 3
> Thanks
We're Progress. Thanks.
I did find an old tech tip for doing something like this.
Close a year short and re-using the Year.
It seems to indicate that the system will keep track of everything, even though there would be two years called 2012.
But I just get the feeling that one long year that ends 12/31/2012 is simpler all the way around.
Any opinions on whether I can assume this would be like any other year end? (Except for having more periods).
> Sent from my iPhone
> Carl Peterson
> > Hi,
> > - Year = 2012
> > - Period = 3
> > Thanks
