I am on Vantage 8.03.409C and we have the DMT Tool. We have adp excel report with our account numbers which the controller imports into the GL with all the accounts from ADP excel report on the payroll.
We are moving to ADP at the end of the year. Getting rid of our Sage Abra. Does anyone import payroll entries directly into the G/L?
I don't know if ADP can produce an import file for you or not. Here is how we do it. I get data from our payroll provider (Paychex). I run that through an Access database which spits out a csv file. In Epicor, I create a journal entry. Then I copy/paste insert the contents of the csv file into the list for the journal entry detail. It took a lot of work to set up the Access translation process, but with that out of the way, it now takes me about ten minutes to make a payroll entry.
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
"The World Leader in Back-lit Mirrors & Mirror TV Technology"
T 425 776-4946
A 11831 Beverly Park Rd, Bldg D, Everett, WA 98204 USA
www.electricmirror.com<http://www.electricmirror.com>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mmcwilliams22
Sent: Thursday, November 12, 2009 12:01 PM
Subject: [Vantage] G/L Import
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
They called to ask how I would like the output format. I am going to test pasting from excel into journal entry then see if they will just send the output in that format.
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
We copy and paste from Excel also. Our ADP payroll reports come in on a CD
in Adobe Acrobat PDF format. Someone from HR highlights the items they need
to enter, then types those required entries (about 160) from the reports
into fields in an Excel worksheet that we created to match the wording and
flow of the ADP reports. Formulas verify everything adds up correctly.
Another worksheet in the same Excel workbook links all the GL Journal
transactions to the fields from the HR worksheet. The spreadsheet is given
to accounting, they hide any lines that are highlighted a certain color
(entries that are blank for this payroll period because they do not apply),
then copy and paste the rest into Epicor. It works great and doesn't take
very long (about an hour including time for both HR and accounting). The
spreadsheet did take quite a bit of time to develop, but prior to developing
it, accounting was entering the reports directly into GL journal entries
which produced numerous errors and took at least 3 times as long to process
each payroll.
ADP does have a product called GL InfoLink that can export whatever
transactions you want to a file. However, ADP charges you by # of employees
on each check run. With the limited # of GL transactions we have, we
calculated that our manual method costs less than half as much for each
payroll than it would if we paid ADP for an export. If we needed a lot more
data elements from the ADP reports, it might be worth paying for the
exports.
Hope that helps.
Dan Snyder
IT Manager
Mercury Electronics
717-428-0222 ext.224
_____
Thomas Rose
Sent: Thursday, November 12, 2009 3:36 PM
Subject: RE: [Vantage] G/L Import
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
www.electricmirror.com<http://www.electric <http://www.electricmirror.com>
mirror.com>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
each payroll.
exports.
Hope that helps.
Dan Snyder
IT Manager
Mercury Electronics
_____
Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
mirror.com>
Can you go over the steps that you perform to create the journal entry and then copy the data into it? I'm needing to do EXACTLY what you are doing only with an ADP created file.
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
We currently use ADP and we DMT are journal entries into the G/L. We found out that was much easier than the GL import functionality.
Deirdre Sykes | Senior Cost Accountant
GSI Technologies, LLC | 311 Shore Drive | Burr Ridge, IL 60527
dsykes@...<mailto:dsykes@...> | Phone: 630.590.8112 | Fax: 630.325.8197
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of flexial_ma
Sent: Wednesday, May 29, 2013 5:47 PM
Subject: [Vantage] Re: G/L Import
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Thomas Rose <t.rose@...<mailto:t.rose@...>> wrote:
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of mmcwilliams22
CONFIDENTIALITY: The information contained in this email message, including any attachment(s), may be privileged and confidential and protected from disclosure. The email is not intended for transmission to, or receipt by, any unauthorized persons. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication or use of the information contained herein is strictly prohibited. If you have received this electronic mail transmission in error, please delete it from your system without copying or disseminating, and notify the sender by Reply email, so that our address record can be corrected.
Deirdre
We are still on Vantage 8 at the moment. To my knowledge, there is no DMT available correct?
Sent from my iPhone
Sent from my iPhone
On May 30, 2013, at 8:14 AM, "Deirdre Sykes" <dsykes@...<mailto:dsykes@...>> wrote:
dsykes@...<mailto:dsykes%40gsitech.com><mailto:dsykes@...<mailto:dsykes%40gsitech.com>> | Phone: 630.590.8112 | Fax: 630.325.8197
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of flexial_ma
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com<http://40yahoogroups.com>>, Thomas Rose <t.rose@...<mailto:t.rose@...>> wrote:
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
> www.electricmirror.com<http://www.electricmirror.com><http://www.electricmirror.com>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com<http://40yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com<http://40yahoogroups.com>>] On Behalf Of mmcwilliams22
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com<http://40yahoogroups.com>>
