Hi,
Thanks for the great insight, will need to review and a couple of
things but it is great to have such feedback. I think we will need to
look how we are physically moving stock and what device is
appropriate for it. Alot to ponder.
--- In
vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
wrote:
> Have you seen the handheld user interface yet?
> When I worked for Epicor, barcoding and wireless handhelds were my
forte. I've done about 50 installs of varying magnitude.
> I always saw disappointment on the customers' faces after the
install. The handheld UI is clunky, limited and not intuitive for
most typical shop floor employees. The menus and screens have their
limitations with customizing, too. There is limited real estate on
the screen.
> I always rolled out Symbol MC9090G's. They're rugged and I've
dropped one (purposely) from a scissor lift about 20 feet in the air
and it was fine after. Motorola owns Symbol now. The other
cool/great thing about Symbol is they have a "shell" application
called Symbol AppCenter. This sits on top of the Windows Mobile UI
and really locks it down so your shop floor employees can't Google or
play Freecell on the handheld while camped out in the corner of the
warehouse on a truck. AppCenter is FREE and ONLY works on Symbol
handhelds.
> However, with that said, in my humble opinion, the wireless
handhelds are a waste of money. Again, the Vantage Handheld UI is
clunky and difficult to get the typical Picker or Shipping Guy to
learn. It's just not intuitive and it looks ugly.
> If you are adamant about having wireless capabilities, allow me to
make 2 alternate suggestions:
> 1) Depending on how far from the physical PC you need to be, check
out the Symbol LS4278. It looks similar to the tethered USB Symbol
LS2208 however it uses Bluetooth technology. This works great for
MES terminals, manifest stations and other job traveler scanning
operations around the shop floor. You have about a 50' radius of
connectivity from the MES workstation. I sometimes couple this with
a nice Stealth Pioneer POS touchscreen. Slick.
> 2) I started rolling out tablet PC's in lieu of handheld wireless
scanners. Tablet PC's can run the familiar MES interface and you can
have a tethered Symbol LS2208 connected to it. I also attached these
to little push carts. It was great for Picking as they could fill up
the cart and scan on-the-fly. Very nice.
> Those two suggestions are also money savers. You don't need to buy
the Handheld Module. You don't need to spend $4000 per wireless
handheld scanner (including docking/charging station, extra
batteries, holster, etc).
> You also do not need to have Microsoft Terminal Services; REQUIRED
if you use the wireless handhelds... or Citrix. Logging in with a
handheld is painful to your domain.
> Depending on how large your shop floor is, making an investment in
to Wireless Access Points can be another costly pain. If you cannot
touch all parts of your warehouse with one AP, then you need to buy
up to a better wireless system that manages multiple APs in your
warehouse and treats them all as one virtual AP. Otherwise, as your
handheld gets out of range, you've now dropped your signal, orphaned
a Terminal Server/Citrix connection and have a hung MES license on
the server. And, your shop floor employee using the handheld is
confused and frustrated.... and calling IT for help.
> If you haven't seen the handheld UI yet, I suggest you do so before
moving forward.
> Good luck.
> Vic Drecchio
> ERP Administrator
> TIMCO Aviation Services
> Greensboro, NC
> Email:Â Â vic.drecchio@...
> Office:Â 336.668.4410 x3091
> Mobile:Â 704.530.3092
> -----Original Message-----
Behalf Of brychanwilliams
> Sent: Thursday, January 08, 2009 7:24 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: General Advice on Handhelds
> Hi , Sorry. Yes definitely wireless. The main transactions will be
> receipts, transfers and issues(Job and Transfer Order).
> Thanks
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@>
> wrote:
> > Do you NEED/WANT *wireless* handheld scanners? (ie, Symbol MC9090)
> > Or can you do it all with corded barcode scanners connected to a
> Vantage
> > workstation? (ie, Symbol LS2208)
> > Big Big difference between each.
> Behalf
> > Of brychanwilliams
> > Sent: Thursday, January 08, 2009 7:19 AM
> > Subject: [Vantage] General Advice on Handhelds
> > Hi,
> > I was wondering if anybody could pass on some advice on
handhelds.
> We
> > are looking to deploy the module with barcoding. We are looking
for
> > some direction on the device itself. I know epicor recommend
> certain
> > devices.
> > We would like to do the following with the devices amongst others;
> > 1) The device to have a barcode scanner to scan part serial
numbers
> off
> > actual supplier parts.
> > Generally, looking for a real world experience in warehouse
> environment
> > using barcoding.
> > Thanks in advance
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
