General Ledger Detail on Windows Vista OS-Vantage 6.0
This may sound foolish, and I do not have v6 to try, but can you set the compatibility for the vantage icon on your vista machine to run in XP compatibility mode and then try it?
I have seen people get around lots of things by doing this.
Carey
To: vantage@yahoogroups.comFrom: rlunsf@...: Tue, 3 Apr 2007 19:59:39 +0000Subject: [Vantage] General Ledger Detail on Windows Vista OS-Vantage 6.0
I have purchased a new PC with Windows Vista installed. Vantage loaded fine and I had a few issues with the correct screen size, fonts, icons, etc., but nothing major. I have, however, found that I cannot print a detailed general ledger report. If you select "detail" it only prints the summary. I have to go to terminal server or an "XP" machine to print out the detail. I asked support, but they responded by saying they will only support Vista on Vantage 8.0. Has someone with Vista ran across this and been able to work around it?
_________________________________________________________________
Live Search Maps � find all the local information you need, right when you need it.
http://maps.live.com/?icid=wlmtag2&FORM=MGAC01
