Generate PDF from a BAQ report
How hard would it be to change this code to preview or print the report instead of exporting it to a PDF?
For some reason the BAQReport Designer has issues exporting my Extended field data to crystal, so I am not seeing any values there even though the BAQ shows values. I am going to try this method to build the table that I want to use and hopefully that works for me.
Hi, all,
Is there any way to generate PDF files with the result of a BAQ report without user seeing the report on the screen?
Search for Logicity - not sure it will do what you want but it might.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tue, 10 May, 2011 15:35:25
Subject: [Vantage] Generate PDF from a BAQ report
Â
Hi, all,
One approach is to run the BAQ via its business object and then pass the resulting data to a crystal report object.
To call a BAQ you use the DynamicQueryAdapter. using this BO you can add filter criteria. It will return a single table dataset. This dataset can be passed directly to the crystal object. Once you have the dataset you can call crystal using very plain vanilla .net code.
I can send you some example code.
Jim Kinneman
Senior Consultant
Encompass Solutions, Inc
--- In vantage@yahoogroups.com, Bill Wu <billw@...> wrote:
> Hi, all,
> Thanks
Hi Jim,
I'm interested, too, in your code.
Thanks in advance -
Laraine
> Jim Kinneman
> Senior Consultant
> --- In vantage@yahoogroups.com, Bill Wu <billw@> wrote:
> > Hi, all,
> > Thanks
FOr what is worth there are several examples of this already on the list
look for Email with Subject
Can Grid on a Custom Sheet be bound to a BAQ?
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Tue, May 10, 2011 at 5:22 PM, laraines422 <laraines422@...> wrote:
> Hi Jim,
> Thanks in advance -
> Laraine
> > Jim Kinneman
> > Senior Consultant
> > > Hi, all,
> > > Thanks
Hi Jose,
I found the post that you referred to - but BAQ Views are available in E9 only, correct?
Laraine
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi Jim,
> > Thanks in advance -
> > Laraine
> > > Jim Kinneman
> > > Senior Consultant
> > > > Hi, all,
> > > > Thanks
Indeed you are right. I didn't realize you were on 8
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, May 10, 2011 at 6:37 PM, laraines422 <laraines422@...> wrote:
> Hi Jose,
> only, correct?
> Laraine
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi Jim,
> > > Thanks in advance -
> > > Laraine
> the
> add
> can be
> can
> > > > Jim Kinneman
> > > > Senior Consultant
> > > > > Hi, all,
> report
> > > > > Thanks
Thanks, Jose - admittedly, we are dragging our feet a bit on the upgrade. But with all the grief that I've heard about going from 6 or 8 to E9 - foot-dragging may be a good thing! :-)
We'll let the rest of you guys on E9 figure it out for us - maybe we'll wait for E10....
L.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi Jose,
> > only, correct?
> > Laraine
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Tue, May 10, 2011 at 5:22 PM, laraines422 <laraines422@> wrote:
> > > > Hi Jim,
> > > > Thanks in advance -
> > > > Laraine
> > the
> > add
> > can be
> > can
> > > > > Jim Kinneman
> > > > > Senior Consultant
> > > > > > Hi, all,
> > report
> > > > > > Thanks
I haven't done a VB version in quite awhile and wasn't able to locate any. The steps are pretty straight forward so converting to VB shouldn't be too involved. This example was originally run from a report screen but the code is generic enough to show how to call from any button.
1. Create BAQ and associated Crystal Report as normal. Easiest if you just use BAQReportResult table. Otherwise you will need to build the other tables.
2. Get the BAQ you want to run
3. Add any where criteria
4. Run the BAQ, it returns a single table dataset
5. Do any table tweaking to match what the crystal report expects
6. Use the crystal report you built for this BAQ using the standard BAQ Designer
7. Point crystal to use the dataset return by the BAQ.
// Custom C# code for BAQReportForm
// Created: 4/12/2010 3:52:57 PM
using System;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using System.ComponentModel;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Searches;
using Epicor.Mfg.BO;
// you will need to copy the dlls for these into your \client directory, probably don't need all of them, never went back to see what we can do without
using CrystalDecisions;
using CrystalDecisions.Shared;
using CrystalDecisions.CrystalReports;
using CrystalDecisions.CrystalReports.Engine;
using CrystalDecisions.ReportSource;
using CrystalDecisions.Windows.Forms;
public static class Script
private static CrystalReportViewer crystalReportViewer1 = new CrystalReportViewer();
private static ReportDocument cryRpt = new ReportDocument();
private static DataSet dsTempReport = new DataSet();
public static void InitializeCustomCode()
btnCreatePDF.Click += new System.EventHandler(Script.btnCreatePDF_Click);
public static void DestroyCustomCode()
btnCreatePDF.Click -= new System.EventHandler(Script.btnCreatePDF_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private static void btnCreatePDF_Click(object sender, System.EventArgs args)
// defaults to client directory, this is what it is on my system
// could add path to file name to override default location
// C:\Program Files\Epicor Software\Epicor904\client
using(oTrans.PushDisposableStatusText("Creating PDF", true))
WritePDF("Test FileName.PDF");
private static void WritePDF(String FileName)
// this is the BAQ we want to run
String BaqID = "BAQThatIwantToRun";
QueryDesignDataSet ds;
// this is used with the whereitem call to adjust the selection criteria
// these have to be tables that are in your baq.
String pcQueryID = BaqID;
String pcTable = "BOLHead";
String pcField = "BOLNum";
String pcCondition = "=";
Boolean pbIsConst = true;
String pcValue = String.Empty;
String pcToTable = String.Empty;
String pcToField = String.Empty;
String pcLeftParentheses = String.Empty;
String pcRightParentheses = String.Empty;
String pcAndOr = String.Empty;
Boolean pbNeg = false;
// crystal report
// this is the location of the crystal report file
// replace it with the location of the crystal report you want to use
string reportname = @"C:\Epicor904\Server\reports\CustomReports\My Crystal Report.rpt";
// load the report
cryRpt.Load(reportname);
// If seletion criteria is needed we need
// to load the query and then add selection criteria before running it instead
// of directly executing it.
DynamicQueryAdapter adDynamic = new DynamicQueryAdapter(BAQReportForm);
adDynamic.BOConnect();
// this woudl be used for BAQ that require NO additional selection criteria
//adDynamic.ExecuteByID(BaqID);
adDynamic.GetByID(BaqID);
// this is used for interactive use, scheduled would lookup any values it needs
EpiDataView edvReport = (EpiDataView) oTrans.EpiDataViews["ReportParam"] ;
ds = adDynamic.QueryDesignData;
// This is the BOL number taken from the screen
// this shows that we can dynamically alter the BAQ selection criteria
// for example we may need to run the report for a differant customer
// for this example we are limiting it to the BOL number entered by the user at the moment
// replace this with values from the screen you are working with
pcValue = edvReport.dataView[edvReport.Row]["Field1"].ToString();
adDynamic.AddWhereItem(ds, pcQueryID, pcTable, pcField, pcCondition, pbIsConst, pcValue, pcToTable, pcToField, pcLeftParentheses, pcRightParentheses, pcAndOr, pbNeg);
adDynamic.Execute(ds);
// if we have followed the normal BAQ report design path the crystal report
// is expecting a three table dataset that we need to build
// "BAQReportResult", this is the result of the BAQ
// "BAQReportParameter", has the values passed to report from the report screen
// includes any filter information entered by user i.e. Order Number, etc
// and "Report Title"
// "Company" has company information
// if you are NOT using ANY fields from "Company" and "BAQReportParameter" you do not
// need to build them. Frequently I do not bother using these other fields.
DataTable dtSelect = new DataTable("BAQReportResult");
// need to clone structure so that importrow works
dtSelect = adDynamic.QueryResults.Tables[0].Clone();
dsTempReport.Tables.Add(dtSelect);
// table from query is called "result", we need to rename it
dsTempReport.Tables[0].TableName = "BAQReportResult";
DataTable dt1 = new DataTable("Company");
// add columns by code
dt1.Columns.Add("Company", typeof(string));
DataTable dt2 = new DataTable("BAQReportParameter");
// add any columns/fields that the report is using
dt2.Columns.Add("Company", typeof(string));
dt2.Columns.Add("ReportTitle", typeof(string));
// add to dataset
dsTempReport.Tables.Add(dt1);
dsTempReport.Tables.Add(dt2);
// populate with appropirate values
// in this case report doesn't use compnay so we leave it blank
// reporttitle is used so make it somthing the user will like
DataRow newRow = dsTempReport.Tables["BAQReportParameter"].NewRow();
newRow["Company"] = String.Empty;
newRow["ReportTitle"] = "Summary Shipment Report";
dsTempReport.Tables["BAQReportParameter"].Rows.Add(newRow);
newRow = dsTempReport.Tables["Company"].NewRow();
dsTempReport.Tables["Company"].Rows.Add(newRow);
// our dataset now looks the way the crystal report is expecting it
try
DataTable dtUnq = adDynamic.QueryResults.Tables[0].DefaultView.ToTable(true,"BOLHead.BOLNum");
//clear table, this was left over from a looping experiment
dsTempReport.Tables["BAQReportResult"].Clear();
// to see what the input table looks like uncomment this line
//adDynamic.QueryResults.Tables[0].WriteXml("BAQ Report DataSet.xml",XmlWriteMode.WriteSchema);
String BOLHead = String.Empty;
foreach (DataRow MyDataRow in adDynamic.QueryResults.Tables[0].Rows )
BOLHead = MyDataRow["BOLHead.BOLNum"].ToString();
dsTempReport.Tables["BAQReportResult"].ImportRow(MyDataRow);
// just to see what things look like, uncomment this line
//dsTempReport.WriteXml("Report DataSet.xml",XmlWriteMode.WriteSchema);
// now build the report
cryRpt.SetDataSource(dsTempReport);
try
ExportOptions CrExportOptions ;
DiskFileDestinationOptions CrDiskFileDestinationOptions = new DiskFileDestinationOptions();
PdfRtfWordFormatOptions CrFormatTypeOptions = new PdfRtfWordFormatOptions();
CrDiskFileDestinationOptions.DiskFileName = FileName;
CrExportOptions = cryRpt.ExportOptions;
CrExportOptions.ExportDestinationType = ExportDestinationType.DiskFile;
CrExportOptions.ExportFormatType = ExportFormatType.PortableDocFormat;
CrExportOptions.DestinationOptions = CrDiskFileDestinationOptions;
CrExportOptions.FormatOptions = CrFormatTypeOptions;
cryRpt.Export();
catch (Exception ex)
MessageBox.Show(ex.ToString());
catch (Exception err)
MessageBox.Show(err.ToString());
--- In vantage@yahoogroups.com, "laraines422" <laraines422@...> wrote:
> Hi Jim,
> Thanks in advance -
> Laraine
> > Jim Kinneman
> > Senior Consultant
> > > Hi, all,
> > > Thanks
This is exactly I was looking for. Thank you very much for the code, I will convert it to VB. We are on 803.407.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jckinneman
Sent: Tuesday, May 10, 2011 8:53 PM
Subject: [Vantage] Re: Generate PDF from a BAQ report
using System;
using System.Data;
// crystal report
// load the report
// add to dataset
try
try
cryRpt.Export();
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "laraines422" <laraines422@...> wrote:
> Hi Jim,
> Thanks in advance -
> Laraine
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "jckinneman" <jckinneman@> wrote:
> > Jim Kinneman
> > Senior Consultant
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Bill Wu <billw@> wrote:
> > > Hi, all,
> > > Thanks
