Generate PO Suggestions grayed out
How do I get the box for Generate PO Suggestions to be un-grayed?
Which module are you working in?
Hi Mathew, we are using the Kinetic version if that is what you mean by module
Assuming you’re in Part Maintenance and need to get the ‘Generate PO Suggestions’ box to be selectable, have you set the ‘Part Type’ to ‘Purchased’?
Yes, I just tried that and you are correct. Thanks for the help!
No problem at all!
