I have some code that extracts the kineticUserID from the Get parameters snap block. It then refers to a table to get permissions and shows or hides certain pages.
This works flawlessly in Pilot, but for some reason in LIVE, the same snap blocks produces no results. Is there some setting in either CPQ or Epicor in the LIVE environment that is stopping this inquiry?
Ok, so I figured out the issue. As part of the LOADED rules, there is a Safe Function that accesses the Quote Table to find a field. As part of the authentication, I had to create an API-Key. Well, once I deployed from Pilot to LIVE, that API-Key was no good. A few IF blocks and environment checks in the Safe Function and I’m back in business. I guess when it failed, it quite running the rest of the LOADED rule because once I fixed that, its good again.
