/{currentCompany}/Erp.BO.CustomerSvc/
Always returns empty and Status 200 even-though data exists in the table. If anyone sees a dumb mistake please let me know.
Pretty strange, I donât have any issues testing it out. You could try specifying the $top parameter, Iâve seen sometimes when there are multiple rows it wonât return anything unless you specify a how many to return. Thereâs also another call you could try if that doesnât work:
Itâs weird. I can [POST] [/{currentCompany}/Erp.BO.CustomerSvc/CustomerPriceLsts no problem, Just canât retrieve them.
FYI Adam, Your call does work.
Well thatâs good. I guess specifying the $top parameter didnât change anything?
Didnât help
Are you multi company? If so, are you passing the proper info in call header?
Custom headers can be used to adjust server call behavior. These headers implement ICallHeader interface from Epicor.ServiceModel assembly.
For example, CallSettings header allows client to specify Company and Site to use in the call.
Header name: CallSettings Header value: {âCompanyâ:âEPIC03â,âPlantâ:âMfgSysâ}
Nope, Not using Multi-Company.
Thanks for everyoneâs help. decided to use getById_Customer_CustomerPriceLsts.
Ok maybe Iâm wrong. Using filters doesnât work, at least here. See (cli
ck on image). It retrieves all ListCodes.Jeez, Iâm having the same issue. You may be better off just creating a BAQ with parameters and calling that with REST instead.
I submitted a support call on this.
EpicCare response:
2020-03-17 10:52:06 -Mike Chan
Hello Gregg,
Tried calling you and reached âLaura Stormsâ voice message when transferred so I didnât leave a message. I replicated the problem and submitted this issue to development for review. We have seen other instances where certain business objects /methods does not filter through REST so this will likely be flagged as a bug. Will contact you again when we have more information.
thank you,
Mike C.
