Get tableset for Invoice Posting
I am trying to create a method directive BPM to raise an exception and stop the user whenever they try to post an invoice group through A/R Invoice Entry that has an invoice on hold.
I have found the method Erp.InvcGrp.PostInvoices. I created a Pre-Processing BPM for this. I then hoped to simply make a Condition that stated when the InvcHead.HoldInvoice of the changed row is equal to TRUE to Raise an exception that stated the user was trying to Post a group and stop them.
However, I cannot seem to access any tt table or any data with this method. When I put a condition on the BPM Workflow Designer and try to click specified or anything related to a dataset I get the following error:
Warning
Neither table/tableset arguments nor tableset directive variables are defined.
Please define at least one tableset directive variable to use this condition.
Is this a situation that I’m going to have to use custom code to read the InvcHead table? I see that the method is on the InvcGrp. However, I cannot access the ttInvcGrp or any other table with the base widgets. Is there a using or other reference I need to use? Should I be using a different method on this?
I likely can put in a BPM on the printing of the Edit List, but I would prefer to do it at posting, if possible.
Thanks!
Good question
I found a Method that works for this. It is Erp.InvcGrp.PrePostInvoices. Once I used that Method, everything else came together.
Total scope of this project was to stop posting if we had any invoice within the group OnHold, with an InvoiceDtl line of 0 extended price (0 quantity or 0 doc unit price), or with a misc line, but no actual Misc Amount.
I made a Pre-Processing method that had conditions of:
Number of rows in the OnHold query is more or equal to 1
OR Number of rows in the ZeroExtPrice query is more or equal to 1
OR Number of rows in the ZeroMiscPrice query is more or equal to 1
And created queries linking ttInvcGrp with InvcHead (where InvoiceHeld is located), InvcDtl (InvcDtl.ExtPrice), and InvcMisc for the last query. Then put the criteria on the required table, such as InvcDtl.ExtPrice = 0. Last, I put a Raise Exception widget on the true for the condition to tell the user they have invoices that have $0 amounts or Invoices On Hold.
Well, it looks like the query for the InvoiceHead.InvoiceHeld would not pop the message box as expected. I also wanted to report to the user which invoice was the problem. So, I had to create this all as custom code.
/*    This finds the first invoice in group that is On Hold (InvcHead.InvoiceHeld), $0 line price (InvcDtl.ExtPrice), or a misc charge with $0 total (InvcMscRow.DocMiscAmt).
//    It stops the posting process at that point and pops up an Exception message box which explains what the issue is and what invoice is causing it.
//    Only finds the first invoice and stops posting. If there are more after first invoice is fixed, the next posting will stop posting and tell the next issue and invoice.
foreach (var IG in ttInvcGrp)
    var ih = (from InvcHeadRow in Db.InvcHead                                 // Find first invoice on hold
        where string.Compare(IG.Company, InvcHeadRow.Company, true) == 0 &&
            string.Compare(IG.GroupID, InvcHeadRow.GroupID, true) == 0 &&
            InvcHeadRow.InvoiceHeld == true
        select InvcHeadRow).FirstOrDefault();
    if (ih != null)
        string PrintNum = Convert.ToString(ih.InvoiceNum);
        throw new Ice.BLException("Invoice " + PrintNum + " is On Hold. Please remove hold or transfer invoice to Hold Group.");
    foreach (var ih2 in (from InvcHeadRow in Db.InvcHead                      //iterate through each invoice in group with InvcHead
        select InvcHeadRow))
        var id = (from InvcDtlRow in Db.InvcDtl                               //iterate through each invoice in group with InvDtl
            where string.Compare(ih2.Company, InvcDtlRow.Company) == 0 &&
                ih2.InvoiceNum == InvcDtlRow.InvoiceNum &&
                Decimal.Compare(InvcDtlRow.ExtPrice, 0) == 0                  //find any that have $0 total price on line
            select InvcDtlRow).FirstOrDefault();
        if (id != null)
            string PrintNum = Convert.ToString(id.InvoiceNum);
            throw new Ice.BLException("Invoice " + PrintNum + " has a $0 Line. Please add a unit price or quantity.");
    foreach (var ih3 in (from InvcHeadRow in Db.InvcHead                      //iterate through each invoice in group with InvcHead for InvcMisc
        foreach (var id2 in (from InvcDtlRow in Db.InvcDtl                    //iterate through each invoice in group with InvcDtl
            where string.Compare(ih3.Company, InvcDtlRow.Company, true) == 0
                && ih3.InvoiceNum == InvcDtlRow.InvoiceNum
            select InvcDtlRow))
              var im = (from InvcMscRow in Db.InvcMisc                          //iterate through each invoice in group with InvcHead for InvcMisc
                  where string.Compare(id2.Company, InvcMscRow.Company) == 0 &&
                      id2.InvoiceNum == InvcMscRow.InvoiceNum &&
                      id2.InvoiceLine == InvcMscRow.InvoiceLine &&
                      Decimal.Compare(InvcMscRow.DocMiscAmt, 0) == 0            //find first invoice that has misc charges that = $0
                  select InvcMscRow).FirstOrDefault();
              if (im != null)
                  string PrintNum = Convert.ToString(im.InvoiceNum);
                  throw new Ice.BLException("Invoice " + PrintNum + " has a $0 Misc Charge. Please add a unit price or quantity.");
Db.Validate();
