GetPriceListInquiry need help
Never mind, I figured it out.
The PriceListInquiry doesn't return a dataset. Once the GetPriceListInquiry is
called, you access the tables using
adaPriceListInquiry.PriceListInquiryData.Tables. My final code looks like this:
   Dim MorePagesPLI As Boolean
   Dim adaPriceListInquiry As PriceListInquiryAdapter = New
PriceListInquiryAdapter(UD105Form)
   adaPriceListInquiry.BOconnect()
   adaPriceListInquiry.GetPriceListInquiry(etbCustID.Text, String.Empty,
etbPartNum.Text, dsCustomerAdapter.Tables("Customer").Rows(0)("GroupCode"),
dsPartAdapter.Tables("Part").Rows(0)("ProdCode"), eceQuantity.Value, "ALL",
"BASE", 0, 0, MorePagesPLI)
   If
adaPriceListInquiry.PriceListInquiryData.Tables("PriceListInquiry").Rows.Count >
0 Then
    eceVprice.Value =
adaPriceListInquiry.PriceListInquiryData.Tables("PriceListInquiry").Rows(0)("NetPrice")
    etbFoundIn.Text =
adaPriceListInquiry.PriceListInquiryData.Tables("PriceListInquiry").Rows(0)("ListDescription")
   End If
Sent: Fri, July 16, 2010 9:41:22 AM
Subject: [Vantage] GetPriceListInquiry need help
Â
Vantage 8.03.408A Progress
Has anyone used the BO GetPriceListInquiry in a customization? I am trying to
use the following code:
Dim dsPriceListInquiry As Data.DataSet
dsPriceListInquiry = adaPriceListInquiry.GetPriceListInquiry("MH4312",
String.Empty, "6940-02", "DD", "CLN-MC", "2", "ALL", "BASE", "0", "0",
String.Empty)
I get the following compilation error for the last line:
Expression does not produce a value.
Has anyone used the BO GetPriceListInquiry in a customization? I am trying to use the following code:
Dim adaPriceListInquiry As PriceListInquiryAdapter = New PriceListInquiryAdapter(UD105Form)
dsPriceListInquiry = adaPriceListInquiry.GetPriceListInquiry("MH4312", String.Empty, "6940-02", "DD", "CLN-MC", "2", "ALL", "BASE", "0", "0", String.Empty)
Hi Steven,
I haven't used it myself, but I have a snippet of code with it.
I think the first two arguments are supposed to be Company and CustID. Your code looks like its missing one of these.
HTH,
Nigel.
