Pilot is updated to 2025.2.3 and I’ve found that any instance where I’m using a GetRows method to populate a dataview and include a UD field in the WhereClause of that method I’m getting a SQL Injection error. These same calls are not having issues in the 2025.1 Live instance.
I’ve tried a variety of input formats like UDField(“MyField_c”) and [MyField_c] but none have avoided the error.
Does anyone have any tips for making these UD fields work again? I’ve put in a ticket, but wanted to check with you amazing people as well.
This is a known issue. PRB: 0306098 for it exist it is being fixed.
Work-around include the _UD table name in the WhereClause.
whereClause = $"Customer_UD.Larry_c='Monkey'";
It is technically #WorkingAsDesigned (it was re-designed in 2025.2) but it is clearly a mistake because it broke ALL existing code, and thankfully they agreed and are working on a fix already.
Is there someway to hide PRBs if they’re tied to CR or something? I go to the PRB repo in Epiccare and search for this number but it doesn’t find anything.
