Getting instance to current part/job/etc object
Adam asks:
> When writing custom code, is it possible to get an instance to the
> current object loaded without having to reload it again? For instance,
> if I want to set a property on the part, I can GetById("partnum") and
> set it, but if one is already loaded, can I just reference the
> partform, JobEntryForm, etc, and a ref to the object from there.
Absolutely.
> If it is available, what is the syntax?
In your transaction object, there's a collection of data-views that hold all
of the data for the current form. If you look up the EpiDataView in help,
you'll see an example.
CType(oTrans.EpiDataViews("JobHead"),
Dim edvJobHead As EpiDataView = CType(oTrans.EpiDataViews("JobHead"),
EpiDataView)
' You can then access a field with this syntax:
edvJobHead.dataView(JobHead.Row)("FieldName")
HTH,
Mark W.
partform, JobEntryForm, etc, and a ref to the object from there. If it
is available, what is the synatax?
thanks!
The forms access and update data through dataviews. Do a search in
Vantage help for 'EpiDataView' and it is explained somewhat.
But anyway:
<oneline>
Dim edvPartView As EpiDataView = CType(oTrans.EpiDataViews("PartView"),
EpiDataView)
</oneline>
edvPartView.dataView(edvPartView.Row)("FieldName") = somevalue
<oneline>
edvPartView.Notify( New EpiNotifyArgs([PartForm], edvPartView.Row,
edvPartView.Column))
</oneline>
good luck,
Bernie.
instance,
it
> thanks!
