Thanks for the feedback. I will continue to poke around and see if I can get something to work.
--- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@...> wrote:
> I actually meatn LaborHed....
> --- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@> wrote:
> > We used to use them but stopped. From what I recall if you use the fields in End it will go to the LaborDtl.
> > --- In vantage@yahoogroups.com, "drew.pete" <drew.pete@> wrote:
> > > I'm on 8.03.408b. Has anyone had any luck with passing a value entered by the user from the End Activity form to the labordtl table in the db? It looks as though they use temp tables on the End Activity form - End, Emp, Hed, LPart - then update the labordtl table upon completion of the form using the native assembly Epicor.Mfg.UI.EndActivityEntry. It must be possible if they have UD fields for End. If not the End Activity Form any other form in MES to the labordtl table I'm sure would be similar. Any help would be much appreciated.
> > > Thanks,
> > > Drew
