Thank you ver much Stephen, we'll have to consider that. I appreciate your
time.
Betty
Sent: Sun, March 6, 2011 10:43:36 AM
Subject: [Vantage] Re: GL Adjustment for Scrap
Â
Betty,
The reason there is not a G/L account available for the Reason Code of SCRAP is
because it is used to report and expense an item on the Job it was
scrapped/issued.
If you are wanting to scrap items from your inventory that are not assigned to a
specific Job, then you may need to create a new Reason Code under Inventory
Adjustment and send it to the correct G/L Account. Don't forget about the
Reference field during the Inventory Adjustment process -- you can add an
additional note.
Stephen
time.
Betty
Â
Betty,
scrapped/issued.
additional note.
Stephen
--- In vantage@yahoogroups.com, "bhernan153" <bhernan153@...> wrote:
> We are using Vantage 8.03 and are trying to offset GL for Scrap. However,
>Reasons codes associated with GL codes are only available for Inv. Adj and DMR.
>Does anyone do any direct GL adjustments for Scrap?
> Thank you
> Betty
