GL Codes not being copied from PO to AP Invoice
8.03.408B
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> Hi Dele,
> > I'm currently on 408B and and have got a strange problem. All
> > my Part classes and Suppliers have been set up with default
> > G/L codes. I also have a final catchall APAcct.Expense G/L
> > code for anything that falls through the cracks. Inventory
> > interface to G/L is on as well.
> > When I set up a PO(for inventory parts), the G/Ls are
> > correctly selected by the system using the default Part Class G/L.
> > However, when I come to enter the corresponding AP Invoice,
> > these G/L codes are not carried over. Instead the system
> > defaults to the final catchall APAcct.Expense G/L code.
> > This is puzzling as I was under the impression that these
> > were copied from PODetail?
> > Any ideas?
> What version are you running? We had this issue on 9.03.504 and needed a
> one-off from Epicor to fix it. It may be fixed in 504B but I don't remember
> for sure.
> Mark W.
I'm currently on 408B and and have got a strange problem. All my Part classes and Suppliers have been set up with default G/L codes. I also have a final catchall APAcct.Expense G/L code for anything that falls through the cracks. Inventory interface to G/L is on as well.
When I set up a PO(for inventory parts), the G/Ls are correctly selected by the system using the default Part Class G/L.
However, when I come to enter the corresponding AP Invoice, these G/L codes are not carried over. Instead the system defaults to the final catchall APAcct.Expense G/L code.
This is puzzling as I was under the impression that these were copied from PODetail?
Any ideas?
Dele
Hi Dele,
> Any ideas?
for sure.
Mark W.
