GL Entry Error Blank Title 97774
Nick,
If you are on 905.600 this was a bug fixed in 601 from memory.
Regards,
Stephen
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nick
Sent: 15 February 2011 16:18
Subject: [Vantage] GL Entry Error
When attempting to create a journal entry line for a financial period
earlier than the one we are currently in, the message below is received. The
group and header can be successfully created and saved, but the line will
give this error when you try to save it.
Exception caught in: Epicor.Mfg.BO.GLJournalEntry
Error Detail
Message: The GL Journal Entry Header record cannot be found.
Type: Error
Program: bo/GLJournalEntry/GLJournalEntry.p
Method: glJrnDtlMnlBeforeUpdate
Table: GlJrnHed
Row:
Field:
Stack Trace
at Epicor.Mfg.Proxy.GLJournalEntryImpl.Update(GLJournalEntryDataSet ds)
at Epicor.Mfg.UI.Adapters.GLJournalEntryAdapter.Update()
at Epicor.Mfg.UI.App.GLJournalEntry.Transaction.Update()
Inner Exception
ERROR condition: The Server application has returned an error. (7243)
(7211)
Inner Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID,
String procedureName, ParameterSet parms, Boolean persistent, Boolean
internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String
requestID, String fullProcedureName, ParameterSet inparams, Object procId,
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String
requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
at
Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String
procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName,
ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool,
Session connection, PersistentProc persistProc, CallContextDataSet
callContextDataSet)
Any ideas? I think I am going to burn a call to Epicor on this one...just
thought i would try it here first.
Error Detail
Type: Error
Table: GlJrnHed
Row:
Field:
Stack Trace
Inner Exception
(7211)
Inner Stack Trace
at
callContextDataSet)
