# GL Report not showing details after year end **Category:** [Epicor ERP 10](https://www.epiusers.help/c/e10/5) **Created:** 2017-02-07 15:07 UTC **Views:** 3389 **Replies:** 8 **URL:** https://www.epiusers.help/t/gl-report-not-showing-details-after-year-end/37174 --- ## Post #1 by @rapat_mark Our accounting person regularly uses the GL Report to view what transaction have affected certain GL accounts. If we run it for 12/2016 it shows all transaction detail but when running it for 1/2017, no detail shows no matter what report options we choose. I ran the GL Account Summary report and it shows all the details. I ran the Trial Balance and it shows that debits and credits have been applied. When I run the GL Report it shows both the opening and ending balance equal to what the starting balance should be. Did we miss something in year end? We went live in March so this is our first year end since upgrading to 10.0.700.4 from Vantage --- ## Post #2 by @Nancy Some years our finance personnel have forgotten to setup the fiscal calendar... i can't recall what happened. Could this be your problem? --- ## Post #3 by @BoostERP There is a transfer balance process that needs to be run and this is different than how V8 worked. Did this get ran you know? It can be ran more than once, if needed read the help on it. Brad --- ## Post #4 by @rapat_mark Thanks for the ideas. She did run the transfer balance and after reviewing the help, I don't see anything she could have messed up. We only have one book and one calendar. Plus when we run the report the starting balance is correct. I added the 2017 fiscal calendar back in December because it was preventing our AP person from entering something. The only thing I question in there is that the Current Fiscal Year Suffix and Current Year columns are blank. --- ## Post #5 by @BoostERP There is a rebuild GL display process you could try. I have only had to use this to fix a goofy display on the GL chart tracker. I don't know if it will help with your report or not. Brad --- ## Post #6 by @rapat_mark Tried the rebuild but still getting the same results. Thanks anyway Brad --- ## Post #7 by @rapat_mark Called Epicor back and found out there is a one-off fix for the problem. Keeping my fingers crossed that it will do the trick. --- ## Post #8 by @an9res Saludos rapat_mark 1 - Actualiza la nueva versión de 10.0 y verifica que error te genera cuando hace la actualización de proceso de GL... 2 - Verifica que transacción GL esta dando error...? de esa manera nos hacemos una modificación en la base de dato para una posible solución. --- ## Post #9 by @rapat_mark Epicor fixes 152483 and 144143 solved the problem --- **Canonical:** https://www.epiusers.help/t/gl-report-not-showing-details-after-year-end/37174 **Original content:** https://www.epiusers.help/t/gl-report-not-showing-details-after-year-end/37174
