GL to WIP tie out 5.2
I am having a problem with some burden not posting as it should from the amount on the work center. I have one operation backflushing our expense for our truck transporting items to subcontractors and it isn't posting the correct amount to wip but is to the GL - Support is looking at it right now. I hope they find something to help.
Sent: Thursday, December 09, 2004 11:46 AM
Subject: RE: [Vantage] GL to WIP tie out 5.2
If people are backdating transactions, your WIP report will reflect those
transactions, even when they have not been posted to the GL. This could
throw the report and GL out of balance. Also, there is a problem with WIP
Subcontract. If you reject parts from a subcontractor, there is a glitch in
Vantage that does not credit WIP Subcontract for the rejected amount. I have
had to manually correct these transactions with a journal entry for the past
2 years, while waiting for a fix. The fix is supposed to be on the next
patch for 6.1.
We went to 6.1 in November. My WIP report is not matching the GL for
Material, Sub, Labor, or Burden on November 30. However, it is not that far
off. I am currently working to find the problem.
Karen Brodniak
Accounting Manager
425-742-7011 X44
Fax 425-353-8945
karen.brodniak@...
Sent: Thursday, December 09, 2004 8:32 AM
Primarily Material. Subcontract somewhat...but not in direct proportion
(If
entries to Subcontract should be going to material, that adjustment would
not entirely resolve my Material Issue.)
Thank you,
Carol Engen
Controller
Winona Lighting
Phone: 507-454-5113, Ext. 314
Fax: 507-454-4806
e-mail: cengen@... <mailto:cengen@...>
Sent: Thursday, December 09, 2004 10:17 AM
What part of your WIP report is discrepant?
Sent: Thursday, December 09, 2004 11:03 AM
Subject: [Vantage] GL to WIP tie out 5.2
Which do you believe? The GL or the WIP report? I have
reviewed all areas
suggested by Vantage support and have not found the
discrepancy. (no date
issues on WIP report, Product Group GL codes correctly set
up etc., Capture
& Post completed...etc.)
Any suggestions on further review? Is it the WIP report in
error?
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
<http://us.ard.yahoo.com/SIG=129siare9/M=324847.5707096.6763800.3001176/D=groups/S=1705007183:HM/EXP=1102697111/A=2343726/R=0/SIG=12i6imm2s/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102610711938959> <http://us.ard.yahoo.com/SIG=129siare9/M=324847.5707096.6763800.3001176/D=groups/S=1705007183:HM/EXP=1102697111/A=2343726/R=1/SIG=12i6imm2s/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102610711938959>
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=1102610711938959>
<http://us.adserver.yahoo.com/l?M=324847.5707096.6763800.3001176/D=groups/S=:HM/A=2343726/rand=101985503>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Which do you believe? The GL or the WIP report? I have reviewed all areas
suggested by Vantage support and have not found the discrepancy. (no date
issues on WIP report, Product Group GL codes correctly set up etc., Capture
Any suggestions on further review? Is it the WIP report in error?
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1292vl3sk/M=298184.5639630.6699735.3001176/D=groups/S=1705007183:HM/EXP=1102694585/A=2434971/R=0/SIG=11eeoolb0/*http://www.netflix.com/Default?mqso=60185400> click here
<http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S=:HM/A=2434971/rand=734225019>
_____
Yahoo! Groups Links
Primarily Material. Subcontract somewhat...but not in direct proportion (If
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
reviewed all areas
up etc., Capture
error?
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
I can tell you that the times my material or subcontract have been off it has been due to debit memos posting directly to the wip account and/or adjustments made to receipts based on DMRd parts not paid for. The adjustment to the value of the receipt can cause the sub. cont to be off as well as the open dmr report. The only other thing ours has been is something not classified correctly in the part class .. if you are using it.
Sent: Thursday, December 09, 2004 11:32 AM
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
reviewed all areas
up etc., Capture
error?
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129kk2vv1/M=298184.5639630.6699735.3001176/D=groups/S=1705007183:HM/EXP=1102696317/A=2434971/R=0/SIG=11eeoolb0/*http://www.netflix.com/Default?mqso=60185400> click here
<http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S=:HM/A=2434971/rand=280555121>
_____
Yahoo! Groups Links
patch for 6.1.
Karen Brodniak
Accounting Manager
425-742-7011 X44
Fax 425-353-8945
karen.brodniak@...
(If
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
reviewed all areas
up etc., Capture
error?
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
ADVERTISEMENT
Yahoo! Groups Links
