Global alerts not going out
check the epicor-smtplog.txt (or whatever the name is) in mfgwrk803 folder.
This should give you the SMTP detail, where the other log just shows the start/stop status of global alerts.
You can also choose to look at the global alert error screen, I believe under utilities.
Carey
To: vantage@yahoogroups.comFrom: pbparker@...: Wed, 26 Mar 2008 19:20:22 +0000Subject: [Vantage] Global alerts not going out
Anyone know of any reason when global alerts are toggled on that they wouldn't be going out? We have our email configuration set up properly as we're getting BPM emails - however I went and turned on global alerts for "Material has been received complete" and "Operation has been completed". They are both marked active and to send alert.I did set up the alert groups and added the appropriate persons to the alert groups. The Global Alerts Email Server process is running.However, when those events take place, nothing occurs. Even looking into the GlobalAlertsEmail.log file shows nothing at all.Just wondering if there's something common that is missing to get it working. Running 8.03.404.
_________________________________________________________________
In a rush? Get real-time answers with Windows Live Messenger.
http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refresh_realtime_042008
See AnswerBook# 5159MPS.
Basically you need to edit the .mfgsys file under user settings, edit this
line with you smtp server:
<SmtpServer value="smtp.servername.com" />
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 a Fax 401-596-1050
www.maxsonautomatic.com <http://www.maxsonautomatic.com/>
_____
Patrick Parker
Sent: Wednesday, March 26, 2008 3:20 PM
