You only have to submit it once as recurring and runs continuously. It
will not let you submit it more than once by design
Gary Parfrey
Dot Net IT Limited, Reg No 4412519
Of Fons van der Beek
Sent: 30 August 2007 20:12
Subject: [Vantage] Global Alerts / Scheduling - Similar Process is
already running
We have several companies defined in Vantage 8.03
I've defined 1 system agent containing several SEPERATE schedules each
schedule containing a Global alert task.
Only the first Scheduled task starts....for al other scheduled task i
get the error message "Simular process is already running"
Did anyone expierence this problem?
Does anybody know a solution to this?
One solution i've tried is changing the interval time from "startup" to
120 seconds with no result, The first task starts fine, all other in
error........
With kind regards
Fons van der Beek
Gary Parfrey
already running
error........
With kind regards
Fons van der Beek
