Global BAQ Blank Title 60263
If in a BAQ you set both companies into the filter with an OR you can
see both companies data without any global settings. You may want to
enable enterprise processing and see whether you can right click into
both companies.
Gary
Of Monte Tomerlin
Sent: 30 October 2007 14:12
Subject: [Vantage] Re: Global BAQ
While I haven't tested this procedure, I would assume when you set
criteria you would set two "equals" criteria, one for each company.
Monte Tomerlin
"laidig.systems" <laidig.systems@...>
wrote:
> I just installed Vantage 8.03.403 and i noticed that when i created a
> global BAQ i no longer am able to retrieve information from our second
> company. In 8.305 this all i had to do was check to global checkbox
> and i could see data from both companies. Does anyone know how to do
> this in 403?
this in 403?
I solved it. Apparently, you have to use Sonic and set up the user to
view External Companies. Then in the Dashboard, you have to set up
the Enterprise options for your query. Kind of cumbersome, but it's
doable.
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
> this in 403?
Monte Tomerlin
> this in 403?
