Global Finite Scheduling
I am curious of any information you can relay to me regarding global
scheduling. We have just went to global forwarding and I am
wondering if you run the global scheduling then mrp and what issues
you have had with the global schedule or any help you can offer.
--- In vantage@yahoogroups.com, "Lepley, Scott A." <sal@...> wrote:
> What version are you running, Nam?
> I am considering this as well. Unfortunately, at this point, we
only use
> the job scheduling function to facilitate the calculations related
to
> time-phase material requirements and purchase suggestions. We are
not using
> Scheduling to plan/monitor/adjust production capacity for two
basic reasons.
> Firstly and primarily, many of our jobs are not sufficiently
planned
> operationally to be conducive to scheduling. Secondly, nobody
seems
> interested in using the scheduling boards. I'm thinking that
perhaps we
> don't have anything to lose by running GFS, but I've been
cautioned in the
> past about doing this. I was advised just to use Job Scheduling
and then
> adjust the production schedule using the scheduling boards, but
that brings
> me right back to my previous statement. Anyway, I would be
particularly
> interested in hearing about pitfalls that others have encountered
with GFS.
> Regards,
> Scott Lepley
> Systems Administrator
> Mauell Corporation
> Phone: 717-432-8686, ext. 14
> Fax: 717-432-8688
> Email: sal@...
> Vantage version: 6.10.532
> -----Original Message-----
> From: progress92000 [mailto:nvong@...]
> Sent: Tuesday, March 14, 2006 8:52 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Global Finite Scheduling
> Hi Everyone,
> I am planning to use Global Finite Scheduling to help avoiding
over
> capacity.
> Anyone has used this Global Finite Scheduling? any impact or must
be
> aware of. What is the best procedures to implement this GFS?
> Would like to have yout input.
> Thanks,
> Nam
I am considering this as well. Unfortunately, at this point, we only use
the job scheduling function to facilitate the calculations related to
time-phase material requirements and purchase suggestions. We are not using
Scheduling to plan/monitor/adjust production capacity for two basic reasons.
Firstly and primarily, many of our jobs are not sufficiently planned
operationally to be conducive to scheduling. Secondly, nobody seems
interested in using the scheduling boards. I'm thinking that perhaps we
don't have anything to lose by running GFS, but I've been cautioned in the
past about doing this. I was advised just to use Job Scheduling and then
adjust the production schedule using the scheduling boards, but that brings
me right back to my previous statement. Anyway, I would be particularly
interested in hearing about pitfalls that others have encountered with GFS.
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
Hi Everyone,
I am planning to use Global Finite Scheduling to help avoiding over
capacity.
Anyone has used this Global Finite Scheduling? any impact or must be
Nam
Morning,
There are many different levels of functionality in Global Finite
Scheduling.
1) The Basic Level - No Finite capacities. This will run just based
on due dates and try to backward and forward schedule as the best it
can.
2) Limited Finite capacity - Some workcenters will have finite
capacity. So it will try and schedule the earliest due dates first
and then take into account the finite capacities.
3) Full finite capacity - all workcenters have finite capacity.
Into the mix goes priority codes which basically gives a capacity
where possible to those jobs with a higher priority code.
In terms of trying to implement global finite scheduling you can
split it into two categories but supplement each other.
Structures
1. Ensure Workcenters and Operations are accurate
a) Number of Machines
b) Hours per machine
c) Finite or not.
2. Calendars are accurate.
Processes
1. Ensure that job bookings are timely.
2. Ensure initial schedule is reasonable
3. Ensure that there is a scheduling process for prior and post
global rescheduling.
4. Ensure that there is a process for updating the shop floor with
the new schedule.
In terms of implementation;
Do a lot of testing, so if you decide that you will reschedule every
monday, take a copy of the database every monday and do a reschedule
on that etc.
I would recommend that you do this a couple times with your current
configuration to assess how accurate it is.
Remember that the global rescheduling is good but it is not a self
contained process , the scheduler will need to manage it so training
and additional will be requried.
The other side benefit, if you have a large number of jobs and
bookings the rescheduling routine seems to clear some things up and
the reports tend to be more accurate. Generally, if possible, keep
it as simple as possible. Don't try and tie everything down. Use the
testing to identify the exact issues, is it the job configuration,
workcenter configurations etc.
I hope this helps.
only use
to
not using
basic reasons.
planned
seems
perhaps we
cautioned in the
and then
that brings
particularly
with GFS.
> Regards,
> Scott Lepley
> Mauell Corporation
> Fax: 717-432-8688
> Email: sal@...
> Hi Everyone,
over
> capacity.
be
> Thanks,
> Nam
Hi Scott,
We are running version 6.1. We are looking for a better way to
schedule the jobs for production plan. We are currently schedule the
jobs according to the due date but we running into over capacity
Nam
only use
to
not using
basic reasons.
planned
seems
perhaps we
cautioned in the
and then
that brings
particularly
with GFS.
> Regards,
> Scott Lepley
> Mauell Corporation
> Fax: 717-432-8688
> Email: sal@...
> Hi Everyone,
over
> capacity.
be
> Thanks,
> Nam
This is a great guide for me.
Nam
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@...>
wrote:
> Morning,
> Scheduling.
based
it
> can.
> Structures
> c) Finite or not.
> Processes
> the new schedule.
every
reschedule
> on that etc.
current
training
and
the
> I hope this helps.
> only use
related
> to
are
> not using
> basic reasons.
> planned
> seems
> perhaps we
> cautioned in the
> and then
> that brings
> particularly
encountered
> with GFS.
> > Regards,
> > Scott Lepley
> > Mauell Corporation
> > Fax: 717-432-8688
> > Email: sal@
> > From: progress92000 [mailto:nvong@]
> > Hi Everyone,
> over
> > capacity.
must
> be
> > Thanks,
> > Nam
Keep in mind that in 6.1 Vantage schedules into the past on operations
that have already started. 8.0 is supposed to change this.
We use Global Finite Scheduling and have switched from finite capacities
to infinite. The problem is that infinite would be great for the shop,
and finite is great for sales (to quote accurate lead times). We still
aren't sure which we like more.
Of progress92000
Sent: Wednesday, March 15, 2006 7:58 AM
Subject: [Vantage] Re: [6.1] Global Finite Scheduling
Nam
wrote:
> Morning,
> Scheduling.
based
it
> can.
> Structures
> c) Finite or not.
> Processes
> the new schedule.
every
reschedule
> on that etc.
current
training
and
the
> I hope this helps.
> only use
related
> to
are
> not using
> basic reasons.
> planned
> seems
> perhaps we
> cautioned in the
> and then
> that brings
> particularly
encountered
> with GFS.
> > Regards,
> > Scott Lepley
> > Mauell Corporation
> > Fax: 717-432-8688
> > Email: sal@
> > Hi Everyone,
> over
> > capacity.
must
> be
> > Thanks,
> > Nam
Yahoo! Groups Links
Ben,
Is this still the case when the option is not ticked , in
company/job management?
operations
capacities
shop,
still
Behalf
> Of progress92000
> Thanks,
> Nam
> --- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@>
> wrote:
> > Morning,
Finite
> > Scheduling.
> based
best
> it
> > can.
first
capacity
> > Structures
> > c) Finite or not.
> > Processes
with
> > the new schedule.
> every
> reschedule
> > on that etc.
> current
self
> training
> and
keep
> the
configuration,
> > I hope this helps.
we
> > only use
> related
> > to
> are
> > not using
> > basic reasons.
> > planned
> > seems
> > perhaps we
> > cautioned in the
Scheduling
> > and then
but
> > that brings
> > particularly
> encountered
> > with GFS.
> > > Regards,
> > > Scott Lepley
> > > Mauell Corporation
> > > Fax: 717-432-8688
> > > Email: sal@
> > > Hi Everyone,
> > over
> > > capacity.
> must
> > be
> > > Thanks,
> > > Nam
must
access. )
Builder
> Yahoo! Groups Links
Brychan how often do you run Global Finite Scheduling and do you use the
MRP module ?
Sent: Wednesday, March 15, 2006 10:07 AM
Ben,
operations
capacities
shop,
still
Behalf
> Of progress92000
> Thanks,
> Nam
> wrote:
> > Morning,
Finite
> > Scheduling.
> based
best
> it
> > can.
first
capacity
> > Structures
> > c) Finite or not.
> > Processes
with
> > the new schedule.
> every
> reschedule
> > on that etc.
> current
self
> training
> and
keep
> the
configuration,
> > I hope this helps.
we
> > only use
> related
> > to
> are
> > not using
> > basic reasons.
> > planned
> > seems
> > perhaps we
> > cautioned in the
Scheduling
> > and then
but
> > that brings
> > particularly
> encountered
> > with GFS.
> > > Regards,
> > > Scott Lepley
> > > Mauell Corporation
> > > Fax: 717-432-8688
> > > Email: sal@
> > > Hi Everyone,
> > over
> > > capacity.
> must
> > be
> > > Thanks,
> > > Nam
must
access. )
Builder
> Yahoo! Groups Links
Yahoo! Groups Links
I haven't used it in anger for a bit. Didn't use the MRP at all,
there wasn't really an issue with material requirements being
automatically suggested/calculated. Probably, should have made that
clearer.
--- In vantage@yahoogroups.com, "Clint Muhlestein" <cmuhlestein@...>
use the
> MRP module ?
> From: brychanwilliams [mailto:brychanw@...]
> Ben,
> operations
> capacities
the
> shop,
We
> still
On
> Behalf
> > Of progress92000
> > Thanks,
> > Nam
> > wrote:
> > > Morning,
> Finite
> > > Scheduling.
> > based
> best
> > it
> > > can.
> first
> capacity
can
> > > Structures
> > > c) Finite or not.
> > > Processes
post
> with
> > > the new schedule.
> > every
> > reschedule
> > > on that etc.
> > current
> self
> > training
up
> > and
> keep
Use
> > the
> configuration,
> > > I hope this helps.
point,
> we
> > > only use
> > related
> > > to
We
> > are
> > > not using
two
> > > basic reasons.
> > > planned
nobody
> > > seems
that
> > > perhaps we
> > > cautioned in the
> Scheduling
> > > and then
> but
> > > that brings
> > > particularly
> > encountered
> > > with GFS.
> > > > Regards,
> > > > Scott Lepley
> > > > Mauell Corporation
> > > > Fax: 717-432-8688
> > > > Email: sal@
> > > > Hi Everyone,
avoiding
> > > over
> > > > capacity.
> > must
> > > be
> > > > Thanks,
> > > > Nam
You
> must
> access. )
> Builder
> > Yahoo! Groups Links
must
access. )
Builder
> Yahoo! Groups Links
