Global Suppliers
You should check “system Monitor”.
In case to run it once, you should to run “Multi Company Direct Server Process” or “Multi Company Server Process” depending on your setup.
But the best way is to add the process to Task Agent in order to run it automatically.
Stelios
Sent: Thursday, December 11, 2014 4:29 PM
Subject: Re: RE: [Vantage] Global Suppliers
Hi,
1. We have two companies set up.
2. Where would I find this?
Andy
Sent from Yahoo Mail on Android<https://overview.mail.yahoo.com/mobile/?.src=Android>
From:"Stelios Zoumis s.zoumis@... [vantage]" <vantage@yahoogroups.com>
Date:Thu, 11 Dec, 2014 at 13:48
Subject:RE: [Vantage] Global Suppliers
Hi,
Some questions.
1. Do you have setup External Companies between these companies ?
2. Is Multi Company Process active ?
In case that both are ok, in order to see vendor to other company, you should open Supplier Form / Actions and push Link Suppliers in order to select the supplier.
Regards
Stelios
Sent: Thursday, December 11, 2014 2:33 PM
Subject: [Vantage] Global Suppliers
Hi all,
I have Suppliers set up in one company that I now want access to via another company.
I have click 'Global' in Supplier Maintenance but I they do not appear in the other company.
Can anybody shed any light on what I am missing here.
Andy
Hi all,
Andy
Hi,
Some questions.
Regards
Stelios
Hi all,
Andy
Hi,
Andy
Â
<div id="ygrps-yiv-578376155ygrp-text">
  <p>Hi,<br clear="none">
Some questions.
  1.   Do you have setup External Companies between these companies ?<br clear="none">
Regards
Stelios
Hi all,
Andy
</div>
<div style="color:#fff;height:0;"></div></div>
