Ok, thanks.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> For that you would need an unpalatable BAQ not available until 9.5
> But writing your own code you can accomplish it. Basically u need to create
> your methods for handling the inserts so that it knows what to do with the
> extra data
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Fri, Jan 14, 2011 at 11:05 AM, Mike <mikeyto_96@...> wrote:
> > I have some "Part Characteristic UDF's" being used in the Part and OrderDtl
> > tables. The Line List View currently will only allow me to point to any
> > fields in the OrderDtl table. Some of the fields beind used are pre-filled,
> > some are not and some can be either depending on the part being used. We
> > have a spreadsheet setup with the fields we need that the end-user will fill
> > out and then Past Insert into the List View. The end result would be all of
> > the fields are present in the list view with data that is either pre-filled
> > or entered from the spreadsheet.
> > I also saw you mentioned using a BAQ to create a new list view. Would the
> > list view work the same, meaning data can be pasted into it or manually
> > manipulated?
> > Thanks for your help!
> > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Jose Gomez
> > <jose@> wrote:
> > > Can you be more specific? What are you trying to accomplish.
> > > You can create your own class and join the elements there to a bounding
> > list
> > > then bind that to the grid view...
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Fri, Jan 14, 2011 at 10:30 AM, Mike <mikeyto_96@> wrote:
> > > > Has anyone ever been successful in linking a 2nd table to any of the
> > Grid
> > > > Line List Views? I am specifically looking to do so in Sales Order
> > Entry. We
> > > > are on Vantage 8.03.409A. Thank you for your assistance.
