Thanks Jim and Wayne,
The only reason I upgraded to version 3.00 was to register it because I like the way it works and help me in some of the functions that need to get done on a daily basis
around here. I did contact Ground Control support and they asked for the script file witch I gladly sent them. I hope they can give me some answers or maybe its just a
Vantage Problem, O' no not one of those problems again. I thought they were all worked out. We will see, I may just stay with the 2.10 version and register that one. Thanks
I will let you guys know how I make out from support and thanks for your input.
Jeff
Jeff
> The only time I needed that function was at the very first script and I just
> make sure that Vantage is active. I give each script plenty of time to
> complete with built in delays before calling another script from the first.
> Not really a work around but it works for me.
> Like someone else said, I don't think the 2.x version has that problem.
> I'd be happy to help any way I can. I'm not real familar with GC but believe
> the both of us could figure out something.
> Jim
> -----Original Message-----
> From: Jeffrey G. Myers [mailto:myersjg@...]
> Sent: Tuesday, May 14, 2002 1:14 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Ground Control Software Ver. 3.00
> Jim,
> Do you remember what the work around was. I think this is my problem
> also.
> Jeff
> > I'm using GC 3.0 to automate our month end close. It runs 12 different
> > Vantage and custom programs at the end of each month.
> > I have noticed that you cannot get the GC "GetActiveWindow" function and
> > maybe another Window function to work correctly with Vantage. I worked
> > around those. We are on 4.00 and I'm very happy with the results and so is
> > Accounting.
> > Jim Moore
> > GD-OTS
> > Sent: Tuesday, May 14, 2002 12:43 PM
> > Subject: [Vantage] Ground Control Software Ver. 3.00
> > Hay Gang,
> > I'm still running on Vantage 4.00.xxx and would like to know if any of
> > you are using the Ground Control Software version 3.00 ? I was using
> > the version 2.10 and was all working fine, but now when I upgraded to
> > version 3.00 the old script files don't seem to work with vantage
> > anymore. Anyone else have this problem or any suggestions.
> > Jeff
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> have already linked your email address to a yahoo id to enable access. )
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
