Group Print Problem
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...>
wrote:
> > We are running 8.03.305L. When we installed the new "L" patch we
now
> > have a problem when group printing our invoices. Has anyone else
seen
> > this? If so, how did you fix it?
> > Any suggestions??
> Does this happen to the standard version or have you customized
this form? I
> found that at 305J or 305K Epicor changed the Report Data
Definition for
> Invoices and moved Misc. Charges to a different location. I
remapped the field
> and it seemed to fix the issue for us.
> Mark W.
Mark,
We are using a customized form of sorts. The standard form still
works just fine. The only thing that we changed was our logo and
some small appearance things. I thought the Epicor guy remapped the
definitions in a WebEx that we had. We can certainly try it again.
Thanks for your suggestions.
We are running 8.03.305L. When we installed the new "L" patch we now
have a problem when group printing our invoices. Has anyone else seen
Our invoices print just fine when we print them individually. When we
use group print from the actions menu in invoice entry we get some good
invoices and some bad ones. That is what is so wierd about it.
The "bad" ones duplicate misc. charges and sold to addresses. The
invoice total and GL is still fine. It's only the appearance that we
have a problem with.
Any suggestions??
> Any suggestions??
Does this happen to the standard version or have you customized this form? I
found that at 305J or 305K Epicor changed the Report Data Definition for
Invoices and moved Misc. Charges to a different location. I remapped the field
Mark W.
It's a bug! You can get an updated invoice form support I believe. I
have fixed it within the existing form before, but it's a fair bit of
work.
Gary Parfrey
Dot Net IT Limited, Reg No 4412519
Of hunt.dwayne
Sent: 21 May 2008 20:03
Subject: [Vantage] Group Print Problem
Any suggestions??
