Just wondering if anyone can throw me a little advice before we go through this.
We will be using professional services to setup our other Depots (which are all separate legal entities) in Epicor. So far we have just the Main Company (which is also Head Office).
I have had a hunt online and am gathering things to check such as BAQ’s, SSRS Reports, BPM’s, Security etc, which will be the areas I myself expect to be busy with.
Is there any consolidation or inter-company transactions? If so, getting a global GL Chart, customer, part, a number of code tables will be of tremendous importance.
Ask me how I know…
As for the technical stuff - we decided long ago that ALL customizations will be made in a single company and controlled using menu structure and menu security access. Too many folks needed access to multiple companies worth of data or transactions.
This is the way. Although I do try to keep BPMs specifically company specific. Different businesses do things different ways, and if you fail to specify which company a BPM applies to, you can mess with another company’s data.
We try hard to do this. It doesn’t always work out that way.
The other thing to watch is depending on the version forms can be company specific or not. We’ve opted to have one form customization globally. It’s easier on our team for managing what is happening on the screen. It just means that some companies see things that they don’t use.
If you have any user codes, those also become something to watch.
We have 11 companies of which we do operational activities and daily transactions in 3 currently. All of them do some level of multi-company. We picked one direction for parts to flow based on which company is the primary owner of the part (not the main location). There’s just a lot of moving pieces depending on what the company plans to do.
Must not use serial numbers? That bug is still there.
We actually do the opposite. We make all the companies conform to the current business processes (customized or not). If it’s a hard stop … then we update the BPM flow to account/branch for that difference.
Each Depot is a separate legal entity and in some cases will not see certain things in the others.
They will all have different Company REG numbers, VAT number, Bank Accounts, etc so forms will be specific to them.
We will be setting each up as a Customer/Vendor for inter-company transactions rather than shared financials.
Effectively each site will be an island but maybe share Parts, Jobs and labour, some customer and suppliers (but not all) and some other tables, the more the better as we are a small IT team of 3 for the whole business and we don’t want to be buried under a flood of support calls every day and have to maintain a huge number of separate forms and queries!
I am reading through the technical document downloaded from Epicweb to get a better understanding of what to expect and define my part in it.
Just thinking ahead to BAQ’s and wondering how single-Company BAQ’s would work, If I was wanting to create a BAQ for one specific Company, I notice at the moment (we only have one currently) the “Owning Company” field is not changeable.
When we have more than one Company will this become editable so I can select a different one?
BAQs automatically run in the current company context anyway (unless cross company), the bigger risk is Db.*** in your code which is NOT scoped to the current company without the proper where clause.
If you’re going to have some users work in more than one company, but needing to have different levels of access in the different companies (e.g., AR and AP in one but only AR in another) you’ll need to create separate menu securities for each company (not as hard as it sounds, but not a small thing either). By default, Epicor applies the same menu security for a menu entry to every company (e.g., If menu entry A has menu security XXX applied to it, it is the same in every company), so whatever level of access a user has in one company they will have in another by default if you add them to another company. The only way around this is by creating separate menu securities for each company.
I suppose only when Professional Services create something for the new Companies will I really be able to start some kind of meaningful testing but I am chomping at the bit to get started!
