Has anyone tried it?
Has anyone tried this above mentioned tip for setting up the multicompany COA?
If yes, was it successful?
Rishi
Not on COA, but I have used the explained functionality extensively in other areas. Works great.
I have it works just like any other paste insert. You just need to create the COA header first
Also double-check that the column headers are in the same order in both windows or the paste may fail or (worse) insert bad data.
