That would be appreciated.
In Crystal -
In Section Expert - width = 2 Height = .5
In Page Setup Horizontal = 2 Vertical = .5
Works fine
When printing from Print Preview -
Size Width = 2 Height = .50 - even when I rotate 180 degrees - nothing
prints.
Will also get in touch with Zebra at this time.
Thank you,
Cathy
b_ordway
Sent: Wednesday, March 20, 2013 2:03 PM
Subject: [Vantage] Re: Having Problems with labels
Updated drivers for the Zebra?
Or have you looked to see if you can rotate using the clients Zebra printer
server settings?
I seem to remember doing this on an XP client, but it was tricky, the driver
had two places where it had to be set.
I know I made notes last time I set one up - if I can find them I'll forward
to you.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Cathy"
<cathy@...> wrote:
Behalf Of
In Crystal -
Works fine
prints.
Thank you,
Cathy
b_ordway
> Spoke to soonI know the feeling, I remember I had a lot of trouble with these too.
> just a bit Frustrated.
server settings?
to you.
<cathy@...> wrote:
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Spoke to soon - just a bit Frustrated.
> We are on Epicor 9.05.605 -
> Printer Zebra GX430t
> When I print from Crystal - the label is fine.
> When I print from Epicor > Receipt > Actions > Print Labels - it changes
> the orientation.
> I am the only user right now.
> Hope this helps.
Behalf Of
> Cathy<mailto:vantage%40yahoogroups.com>
> Sent: Wednesday, March 20, 2013 10:12 AM
> Subject: RE: [Vantage] Re: Having Problems with labels
> It printing correctly now.
> I can even explain why.
> Thanks for all your help.
> Cathy
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On
> Behalf Of<mailto:vantage%40yahoogroups.com>
> b_ordway
> Sent: Tuesday, March 19, 2013 10:22 AM
> Subject: [Vantage] Re: Having Problems with labelscertain
> Hi Cathy,
> Can you tell us if you are working in V8 or E9?
> Also what label printer and version of Crystal you are using?
> Here is an example of a problem I had that appears to be specific to
> versions.worked.
> V8.03.305L had margin issues on labels that I could not resolve.
> Margin settings when printed from Crystal were fine.
> Printing from V8 they were ignored and 1 inch margins were always used.
> I finally had to patch up to V8.03.409C before the margins on labels
> <mailto:vantage%40yahoogroups.com> , "Cathy"Receipt
> <cathy@> wrote:
> > Now I am getting something when printing through Receipt entry.
> > However, Printing from Crystal it prints just fine - printing from
> > entry it prints like it needs to rotate 180 degrees -<mailto:vantage%40yahoogroups.com>
> > Same report - 2 different results. How can this be fixed?
> > Thank you,
> > Cathy
> <mailto:vantage%40yahoogroups.com> ] On<mailto:vantage%40yahoogroups.com>
> Behalf Of
> > cathyattechnologicsys
> > Sent: Monday, March 18, 2013 4:14 PM
> <mailto:vantage%40yahoogroups.com>nothing
> > Subject: [Vantage] Having Problems with labels
> > I created a label for Receiving. Through Receipt Entry > Actions > Print
> > Labels.
> > I modified the Crystal Report, our label size is 2 inches wide and 1/2
> inch
> > in height.
> > I only have the part number on the label right now.
> > When I print from Crystal Reports (where I created the label) - the part
> > number prints.
> > When I go through receipt entry and print, the label advances but,
> > prints.[Non-text portions of this message have been removed]
> > I am hoping someone has the answer for me.
> > Thank you, Cathy
