Are your appserver logs running? Check the main appserver log to see if you
have any CRC errors.
You can make sure your appservers are using the same schema holders as your
admin tools by checking the file path for the schema holders in both .pf
files they are using for the appservers and the admin tools.
Ned
Alternative Technology Solutions
markbetts66
Sent: Wednesday, March 21, 2012 11:38 AM
Subject: [Vantage] Re: Help 9.05 upgrade from 9.04. Rebuilding a custom
schema holder
Neil,
We can run the database schema update and it completes with no errors.
Is there a way we can check that we are using the right schema holder for
the admin tools? I assumed it would use the same one as for the appservers.
Ned
markbetts66
schema holder
Neil,
--- In vantage@yahoogroups.com, "Ned C." <TechnoBabbly@...> wrote:
> It sounds like you're using the wrong schema holder for your 9.05
> Admin tools OR you haven't run the schema changes on the SQL database
> to update them to the 9.05 level.
> Ned
> Behalf Of
> markbetts66
> Sent: Wednesday, March 21, 2012 10:32 AM
> Subject: [Vantage] Help 9.05 upgrade from 9.04. Rebuilding a custom
> schema holder
> Hi,
> Were are trying to update our Vantage 8.0.408 SQL to 9.05. We can get
> as far as completing a successful 9.04 upgrade but when trying to
> upgrade to 9.05 we get errors on the admin tool about CRC failures.
> Does anyone know how we can merge/rebuild the schema holder based on
> our database?
> Thanks for any help,
> Mark.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
