Help Adding new company in Progress Explorer tool
Did you add the DB to the Admin Console?
Chuck Trites
Senior Software Consultant
Crawford Software Consulting, Inc. (CSCI)
"Bringing Software and Manufacturing Together"
Email: chuck.trites@...
<mailto:Steven.Carr@...>
Phone: (603) 537 - 9630
Mobile: (603) 219 - 1500
Fax: (603) 537 - 9633
Website: www.Crawford-Software.com
Notice: This email message may contain confidential and / or privileged
information. If you are not an addressee or otherwise authorized to receive
this message, you should not use, copy, disclose or take any action based on
this e-mail or any information contained in the message. If you have
received this material in error, please advise the sender immediately by
email or by phone at (603) 537 - 9630 and delete this e-mail message.
Ross Hughes
Sent: Wednesday, July 15, 2009 11:32 AM
Subject: RE: [Vantage] Help Adding new company in Progress Explorer tool
Are your Appserver startup settings pointing to your new PF file?
Behalf Of
DD
Sent: Wednesday, July 15, 2009 9:47 AM
it gives the same message with both logins.
--- On Wed, 7/15/09, Manasa Reddy <manasa@...
<mailto:manasa%40weldcoa.com> > wrote:
From: Manasa Reddy <manasa@... <mailto:manasa%40weldcoa.com> >
Date: Wednesday, July 15, 2009, 9:38 AM
Are you trying to sign in as yourself? Or as MANAGER?
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of DD
Sent: Wednesday, July 15, 2009 9:30 AM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] Help Adding new company in Progress Explorer tool
Help. I am adding a new company in it's own database.
I have set up the Progress Explorer tool with the database configuration
and the 3 app server configuration the same as the Pilot database.
(changed port numbers on Pilot)
Then I setup the mfgsys file in the client config folder.
then I setup the pf file in the server config folder.
It looks to start correct and log files are clean at that point.
When I try to log into the database using the new shortcut that points
to the new mfgsys file then I get and error message Unable to logon as
title of the error box and the contens of the error is Access Denied
(bo.userfile)
Anyone have a clue what I am missing?
I have set up the Progress Explorer tool with the database configuration and the 3 app server configuration the same as the Pilot database. (changed port numbers on Pilot)
Â
Â
When I try to log into the database using the new shortcut that points to the new mfgsys file then I get and error message Unable to logon as title of the error box and the contens of the error is Access Denied (bo.userfile)
Â
Â
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of DD
(bo.userfile)
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of DD
(bo.userfile)
Remember, since it is a new database, using your user id is useless.
MANAGER is the only one you can use.
You said you copied the settings from the Pilot db. Did you change all
the paths within the app servers' areas in Progress explorer? Meaning
when you right click and go to properties, there are settings within the
broker and agent that need to point to your new db.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
(bo.userfile)
This is a converted database that was converted to the standard epicor904 database then backup and restore to the new name.
Â
Yes the setting in the app server sections of the PET are correct.
Â
Date: Wednesday, July 15, 2009, 9:53 AM
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of DD
--- On Wed, 7/15/09, Manasa Reddy <manasa@weldcoa. com
<mailto:manasa% 40weldcoa. com> > wrote:
From: Manasa Reddy <manasa@weldcoa. com <mailto:manasa% 40weldcoa. com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
Of DD
(bo.userfile)
Aahh, ok.
What about the target on the icon itself?
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of DD
Sent: Wednesday, July 15, 2009 10:04 AM
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
(bo.userfile)
target on the icon has the /config = xxxx.mfgsys
the mfgsys file is in the client folder on the workstation.
I already have 2 of the databases converted and running and did not have the problem with them.
This one is setup the same except for the paths and ports.
(does the same on the server itself)
Date: Wednesday, July 15, 2009, 10:13 AM
Aahh, ok.
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
(bo.userfile)
Then I would talk to tech support at this point...or maybe someone else
on the list can help at this point...sorry!
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of DD
Sent: Wednesday, July 15, 2009 10:22 AM
Aahh, ok.
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Behalf
Of DD
(bo.userfile)
My guess would be a problem with the DB itself.
Have you tried restoring it again?
Can you log into the Admin tools?
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, July 15, 2009 11:21 AM
> From: Manasa Reddy <manasa@...>
> Aahh, ok.
> M. Manasa Reddy
> manasa@weldcoa. com
> P: 630-806-2000
> F: 630-806-2001
> Of DD
> M. Manasa Reddy
> manasa@weldcoa. com
> P: 630-806-2000
> F: 630-806-2001
> Behalf
> Of DD
> M. Manasa Reddy
> manasa@weldcoa. com
> P: 630-806-2000
> F: 630-806-2001
> Behalf
> Of DD
> (bo.userfile)
> have already linked your email address to a yahoo id to enable access. )
DD
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of DD
(bo.userfile)
