Help adding NonConformance table to Corrective Action Form using
Depending on the purpose of adding the Nonconformance 'table' and what version you are on, I would recommend instead of using a FKV, to create a BAQ of the Nonconformance data you need to view, create a dashboard from that and then add the dashboard to the Corrective Actions program via a customization and the dashboards Publish/Subscribe functionality with the NonConfNum field. If you need to update the nonconformance table then make the BAQ & Dashboard updatable. it's really not that hard once you do it once. If you need help, let me know and I can provide examples.
-Rick Bird
IT Software Administrator
Rowmark, LLC.
--- In vantage@yahoogroups.com, "DaveO" <daveolender@...> wrote:
> I would like to add the nonconformance table as a FKV (Foriegn Key View) to the Corrective Actions form (part of DMR).
> I don't see how to add the table, it is not listed in the associated tables when adding a FKV.
> Any help would be geatly appreciated.
> Thanks,
> DaveO (and Paula)
DaveO (and Paula)
