My experience was that this error "Unable to open help file" happened when
an NT workstation had opened the help file. I did make the Vantage help
file read only-but it didn't work until I did it with all of the
workstations (except three data collections) down. Then I quit getting the
error.
Lydia
Sent: Monday, January 21, 2002 8:20 AM
Subject: RE: [Vantage] Help Files 5.1
Do You have any Custom code?? Vantage usually
recommends that you but all custom work in a "Custom"
folder and modifying the ProPath in the Vantage.ini
file to point there first. You may have success if
you move the Help folder under the Custom folder.
--- Les Tingley <ltingley@...> wrote:
Do You Yahoo!?
Send FREE video emails in Yahoo! Mail!
http://promo.yahoo.com/videomail/
error.
Lydia
> Hi Jim. Changing to read only didn't help in my__________________________________________________
> case. I did get it to work
> by coping the Help folder to the users C:\vntgwk51
> folder, and pointing a
> shortcut file to it (called help.lnk) from the
> vantage folder on the server.
> > From: Zerfass Jim [SMTP:jimzerfass@...]
> > Sent: Friday, January 18, 2002 3:41 PM
> > Subject: Re: [Vantage] Help Files 5.1
> > Yes. I'm running 4.00.904 but have had similar
> > problems. Usually, it's someone sitting with the
> Help
> > open and minimized (sometime 2 and 3 copies)
> > Try making your Vantage Help folder read only. It
> > solved the problem for me.
> > --- lptingley <ltingley@...> wrote:
> > > I've got a handful of units that can't use the
> Help
> > > Screens. The
> > > error message reads:
> > > "Cannot display this help file. Try opening the
> help
> > > file again,
> > > and if you still get this message, copy the help
> > > file to a different
> > > drive, and try again."
> > > Reinstall of just Vantage Client does not
> correct
> > > this. Has anybody
> > > seen this?
> > > Thanks,
> > > Les Tingley
> > > MIS
> > > Decorated Products
> > > ------------------------ Yahoo! Groups Sponsor
> are:
> > > ( Note: You must have already linked your email
> Yahoo!Group
> > > for Report Builder and Crystal Reports and other
> Vantage
> > > services goto:
> > Do You Yahoo!?
> > have already linked your email address to a yahoo
> services goto:
> services goto:
Do You Yahoo!?
