Lori,
Not certain I can help, I thought that the 599 error had to do with the
database file locations. Check this out see if it helps
http://support.crystaldecisions.com/library/kbase/articles/c2002982.asp
<http://support.crystaldecisions.com/library/kbase/articles/c2002982.asp>
Dan Shallbetter
States Electric
Sent: Friday, November 01, 2002 11:17 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Help Please - Crystal Reports
It's very possible that in most instances, I will be using for example the
part file and that's the file that the user's report is using as well. That
probably happens all the time. The Crystal dlls are not on the server.
Lori
Sent: Thursday, October 31, 2002 6:35 PM
Subject: Re: [Vantage] Help Please - Crystal Reports
Lori,
If the you are trying to modify the same file that a user is viewing a
report from, then Yes, you will get an error message because of file
sharing. But I can't see how that would ever happen if you were modifying a
different file.
If you are trying to work on the same file that someone might possibly view,
then what you might try is making a copy of the file before you modify it.
Then modify the copied file. When you have finished your modifications, then
you can save the file as the original name (if it's not in use at the time).
On the other hand, if you are getting errors modifying DIFFERENT files, then
perhaps somehow you are sharing the same .dll files as the Vantage server
and there is a conflict there. Is Crystal on the Vantage server by any
chance?
Troy Funte
Liberty Electronics
Dan Shallbetter
States Electric
Lori
Lori,
different file.
chance?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, October 31, 2002 1:07 PM
Yes, and if I am trying to create/modify a report and a user is already
accessing a crystal report, I cannot. I also get an error message. Any
ideas?
Sent: Thursday, October 31, 2002 10:28 AM
Are you saying this only happens when you are modifying a crystal report
at
the same time that a user is accessing a different report?
Troy Funte
Liberty Electronics
To: Vantage Onelist (vantage@onelist.com)
Sent: Thursday, October 31, 2002 12:13 PM
Subject: [Vantage] Help Please - Crystal Reports
I have created several Crystal Reports that are used by my users
throughout
the day. Whenever I am in Crystal, creating or modifying reports and my
users are trying to access already created reports through Vantage, they
get
a 599 error. Can anyone help me solve this problem? I need to be able to
work in Crystal and have users generate reports.
Lori
Lori A. Baker
Director of Information Systems
WindStone Medical Inc. (formerly Cardio Pak Inc.)
406.259.6387
lbaker@... <mailto:lbaker@...>
www.windstonemedical.com < http://www.windstonemedical.com/
<http://www.windstonemedical.com/>
< http://www.windstonemedical.com/ <http://www.windstonemedical.com/> >
< http://www.windstonemedical.com/ <http://www.windstonemedical.com/> <
http://www.windstonemedical.com/ <http://www.windstonemedical.com/> > > >
