Help Required ! Installation issues
You don't really need Epicor to do it, you just need someone who knows what
they are doing to do it.
Paul,
Chances are you are trying to install some piece on the C drive, which
should never ever be done, even though it defaults to the C drive, every
single installation should always be done to a secondary drive.
Len Hartka
Sent: Sunday, August 01, 2010 1:42 PM
Subject: RE: [Vantage] Help Required !!!!!! Installation issues
Good Day Paul:
Sun is implementing EPICOR 9, SQL (9.05.600B.2) with a 10/4 Go-Live
date. But is currently on
Manage-2000 (Informix not Unix)
What Verion of E9? 9.04 or 9.05
Are you SQL or Informix.
How many servers? 3? : Database, App, Misc(APM, Crystal, etc) Besides three
servers, do you have a Disc Array - Are you virtualized? With 64 bit Host
and at least one 32bit "Instance\Server"
How many users have you migrated your data.
Installation is very complicated. I believe you MUST have Epicor do it
1.There are three pieces to the SQL database
2. If 9.05 you need latest SQL version-- 2008 Enterprose I think.
3. OS version makes a difference.
4. 32 or 64 bit Hardware and OS.
5. Two parts need to remain 32 bit ( AOM and somehting else).
6. Since DB has three parts, each one must go to an appropriate
directory with needed space. That include correftly pointing to the
Disc-Array (if any)
7. How Raided is also important.
len.hartka@...
Of Jose Gomez
Sent: Saturday, July 31, 2010 12:22 AM
Subject: Re: [Vantage] Help Required !!!!!! Installation issues
I think the 4.5 GB may not be less than the requirements ask for.
Sincerely
Jose C Gomez
http://www.josecgomez.com
On Fri, Jul 30, 2010 at 7:54 PM, Paul L Bennett
<paullbennett@...>wrote:
> Anyone I need help... I am installing E9 on my server and the
> installation screams that I don't have enough drive space.... My drive
> C and D has 4.5GB and 353GB free space respectively so this should not
> be the case.... I am desperate right now for a solution can anyone
> help?????
> Paul
This e-mail and any attachments may contain proprietary and/or confidential
information. If you are not the intended recipient, please notify the sender
immediately by reply e-mail or at 410-472-2900 and then delete the message
without using, disseminating, or copying this message or any portion
thereof. With e-mail communications you are urged to protect against
viruses.
Anyone I need help... I am installing E9 on my server and the installation
screams that I don't have enough drive space.... My drive C and D has 4.5GB and
353GB free space respectively so this should not be the case.... I am desperate
right now for a solution can anyone help?????
Paul
Sincerely
Jose C Gomez
> and
> desperate
> Paul
Good Day Paul:
Besides three servers, do you have a Disc Array -
Are you virtualized? With 64 bit Host and at least one 32bit
"Instance\Server"
Disc-Array (if any)
len.hartka@...
Of Jose Gomez
Sincerely
Jose C Gomez
> help?????
> Paul
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Good Day Paul:
Are you sure it is disc space problem, and not CPU memory?
Only latest versions of windows can make use of more then 8M of memory.
len.hartka@...
Of Len Hartka
Good Day Paul:
"Instance\Server"
Disc-Array (if any)
len.hartka@... <mailto:len.hartka%40sunautomation.com>
Behalf
Of Jose Gomez
Sincerely
Jose C Gomez
> help?????
> Paul
