You need to run the Schema Changes to bring everything up to the same level,
you do not need to uninstall 4.0. There should be a Vantage Schema Change
icon created in the Vantage program group on your administrators
workstation. You may need to edit the .vtg file that it points to dependant
upon the database and the service that you need to apply the changes to. You
will be prompted for a password to begin the procedure, the password is
changeschema.
Randy Vander Galien
IS Manager
Wisconsin EPS
Sent: Tuesday, December 26, 2000 9:39 AM
To: vantage@egroups.com
Subject: [Vantage] help! V4.0
We currently upgraded to version 4.0 and previously we tested the
software on our new server. This morning we upgraded our live
database (a copy) and everything went well. The problem that I ran
into was that when I went to log onto vantage for the first time to
perform the conversions, the system prompted me with Schema changes
were require, database was to version 4.06 and vantage version was
4.09. It won't let me continue. It appears that the new created
database is up to 4.06 but because we previously added the patch to
the test database the system detect vantage as a newer version.
Is there anything I can do to bring the database up to version 4.09?,
or am I forced to uninstall vantage 4.0 and begin again?
changeschema.
Randy Vander Galien
IS Manager
Wisconsin EPS
