Help with an alert program for BAM
Hi Mike,
That could be it. AFAIK, the SDK comes with a Progress Developers licence.
We'll see what Rob comes back with.
Thanks for trying.
Nigel.
--- In vantage@yahoogroups.com, "Mike Anstey" <manstey@...> wrote:
> Hmmm. I do have the SDK, but I didn't think my progress license was any
> different on the server. (I am also running unix server side)
> Of Nigel Kerley
> Sent: Friday, May 29, 2009 12:32 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Help with an alert program for BAM
> Hi Mike,
> I'm still getting the same error.
> I've copied/pasted your code into both the BPM and the .p file. I get
> the "found" message in the server log, but immediately followed by "you
> may not compile..."
> Are you sure you don't have a different licence for Progress?
> Nigel.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Mike Anstey" <manstey@> wrote:
> > OK I just tested this and it works just fine! (I used ABCCode Update)
> > with a Pre-processing Method directive.
> > The method directive looks like this:
> > FIND FIRST ttABCCode WHERE ttABCCode.RowMod = "U" or ttABCCode.RowMod
> > "A" NO-LOCK NO-ERROR.
> > message "found " ttabccode.ABCCode.
> > IF AVAIL ttABCCode then DO:
> > RUN ud\Test\testwritingUD01.p( input ttABCCode.ABCCode).
> > END.
> > To create the test program you can use a text editor and it does not
> > have to be compiled. Also since there are no triggers on UD01 the
> first
> > line is not required:
> > /* disable triggers for load of UD01. */
> > DEFINE INPUT PARAM job-shortchar01 AS CHAR NO-UNDO.
> > message "starting ud01".
> > FIND FIRST UD01 WHERE UD01.KEY1 = job-shortchar01 NO-LOCK NO-ERROR.
> > IF NOT AVAIL UD01 THEN
> > DO:
> > CREATE UD01.
> > ASSIGN UD01.KEY1 = job-shortchar01.
> > END.
I would like to create a new record in a UD table when a change is made
to the JobOper.ShortChar01 field. The alert program would first have to
verify the record didn't exist (UD.Key1 field = JobOper.ShortChar01) and
if it did not exist create a new record and then populate the
Character01 field with a static string value concatenated with the value
from the JobOper.ShortChar01 field. If the record does exist, do
nothing. Is this possible? Anyone have any code that does something
similar in concept I could work with? Thanks in advance!
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Hi Rob,
I don't think it's possible to do this. With the Progress licence that comes with Vantage, it's not possible to write 4GL code that alters the database.
Epicor supplied the means of amending existing records (Run lib\UpdateTableBuffer.p) but you can't add new records with this.
If you knew someone with a Progress developers licence, you could ask them to compile a 4GL file for you and then it would work.
One other thing I've recently found is a test .p file in UD\Test "RunBOThru4GL.p". This (as the name suggests) is supposed to allow a user run a Vantage BO from 4GL. If you could get it working maybe you could run the UD##.GetNewRecord directive from 4GL and then populate it.
I had a quick look at it, got it to connect with the database, but I haven't gotten any further. Anyone else ever looked at this?
Nigel.
> Rob Bucek
> FAX: 715-284-4084
I believe you can do it with a BPM (for an action pick "execute 4GL
code") you probably won't have a method call on JobOper.ShortChar01, but
you could probably use the Update method for JobEntry and you should be
fine.
Something like this should work:
FIND FIRST ttJobOper WHERE ttJobOper.rowmod = 'A' OR ttJobOper.rowmod =
'U' NO-LOCK NO-ERROR.
IF AVAIL ttJobOper THEN
DO:
FIND FIRST UDxx. WHERE UDxx.Key1 = ttJobOper.ShortChar01 NO-ERROR.
IF NOT AVAIL UDxx THEN
DO:
CREATE UDxx.
ASSIGN UDxx.Key1 = ttJobOper.ShortChar01.
And so on......
END.
END.
If you want to debug to see if it is working just as a statement like
this:
Message "got this far". (don't forget the "." Or it won't work)
Your message will show up in the server log file for whatever database
you are running against e.g. mfgsys803.server.log
Hope this helps.
Of Nigel Kerley
Sent: Friday, May 29, 2009 10:50 AM
Hi Rob,
database.
Nigel.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
made
to
and
value
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Sorry, Mike, but I don't think so.
I tried (more-or-less) exactly the same code as you have in the alert program and I got the following error in the DB log: "You may not compile programs that update the database in this version (490)".
I get the same error displayed on-screen when I use that code in a BPM and click "Validate".
Nigel.
> fine.
> DO:
> DO:
> CREATE UDxx.
> And so on......
> END.
> END.
> this:
> Hope this helps.
> Of Nigel Kerley
> Hi Rob,
> database.
> Nigel.
> made
> to
> and
> value
> > Rob Bucek
> > FAX: 715-284-4084
Thanks for the response Nigel, my gut feel was that this might be a
little bit of a stretch, I already have several BPM's utilizing the (Run
lib) but wasn't sure so I thought Id throw it out there.
Rob Bucek
FAX: 715-284-4084
Of Nigel Kerley
Sent: Friday, May 29, 2009 8:50 AM
Hi Rob,
database.
Nigel.
made
to
and
value
> Rob Bucek
> FAX: 715-284-4084
Thanks guys! Guess its SC workflow time...
Rob Bucek
FAX: 715-284-4084
Of Nigel Kerley
Sent: Friday, May 29, 2009 9:30 AM
Nigel.
but
be
> fine.
> DO:
> DO:
> CREATE UDxx.
> And so on......
> END.
> END.
> this:
> Hope this helps.
Behalf
> Of Nigel Kerley
> Hi Rob,
the
> database.
it.
> Nigel.
> made
> to
> and
> value
> > Rob Bucek
> > FAX: 715-284-4084
> > <http://www.dsmfg.com/ <http://www.dsmfg.com/> <
http://www.dsmfg.com/ <http://www.dsmfg.com/> > >
FIND FIRST ttABCCode WHERE ttABCCode.RowMod = "U" or ttABCCode.RowMod =
END.
have to be compiled. Also since there are no triggers on UD01 the first
DO:
CREATE UD01.
END.
Of Nigel Kerley
Sent: Friday, May 29, 2009 11:30 AM
Nigel.
but
be
> fine.
> DO:
> DO:
> CREATE UDxx.
> And so on......
> END.
> END.
> this:
> Hope this helps.
Behalf
> Of Nigel Kerley
> Hi Rob,
the
> database.
it.
> Nigel.
> made
> to
> and
> value
> > Rob Bucek
> > FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> > >
Hi Mike,
I've copied/pasted your code into both the BPM and the .p file. I get the "found" message in the server log, but immediately followed by "you may not compile..."
Nigel.
> END.
> DO:
> CREATE UD01.
> END.
> Of Nigel Kerley
> Nigel.
> but
> be
> > fine.
> > DO:
> > DO:
> > CREATE UDxx.
> > And so on......
> > END.
> > END.
> > this:
> > Hope this helps.
> Behalf
> > Of Nigel Kerley
> > Hi Rob,
> the
> > database.
> it.
> > Nigel.
> > made
> > to
> > and
> > value
> > > Rob Bucek
> > > FAX: 715-284-4084
Very cool Mike, I will try this out and let you know next week how it
turned out. Thank you very much.
Rob Bucek
FAX: 715-284-4084
Of Mike Anstey
Sent: Friday, May 29, 2009 10:00 AM
Subject: RE: [Vantage] Re: Help with an alert program for BAM
END.
DO:
CREATE UD01.
END.
Behalf
Of Nigel Kerley
Nigel.
but
be
> fine.
> DO:
> DO:
> CREATE UDxx.
> And so on......
> END.
> END.
> this:
> Hope this helps.
Behalf
> Of Nigel Kerley
> Hi Rob,
the
> database.
it.
> Nigel.
> made
> to
> and
> value
> > Rob Bucek
> > FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> <http://www.dsmfg.com/
<http://www.dsmfg.com/> > > >
Of Nigel Kerley
Hi Mike,
may not compile..."
Nigel.
> END.
first
> DO:
> CREATE UD01.
> END.
Behalf
> Of Nigel Kerley
> Nigel.
> but
> be
> > fine.
ttJobOper.rowmod
> > DO:
> > DO:
> > CREATE UDxx.
> > And so on......
> > END.
> > END.
like
> > this:
database
> > Hope this helps.
> Behalf
> > Of Nigel Kerley
> > Hi Rob,
that
> the
> > database.
ask
you
> it.
> > Nigel.
> > made
have
> > to
> > and
> > value
something
> > > Rob Bucek
> > > FAX: 715-284-4084
