I found the solution last night searcing this group:
Added statement "opts.PreLoadSearchFilter = whereClause;"
Thank you John and Jose for your assistance!
--- In vantage@yahoogroups.com, "zanniebelle" <rwatson@...> wrote:
> Thanks Jose, In reviewing the ARInvoiceAdapter in Object Explorer and in VS2010 debugging the InvcHeadList table does have a GroupID and Posted column, so one would expect that you could filter on them.
> I need to populate the ARInvoice.ARInvoiceList with invoices that belong to a specific group. Much like the framework populates the ARInvoice Entry screen when a user enters or selects a group Id.
> Many of the controls on that screen are bound to InvcHeadList not InvcHead.
> If I do a RowDataSet search using InvcHead the results returned are correct but ARInvoice.ARInvoiceList is not populated.
> Thanks!
> --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > You can't do whereclauses on fields that are not available on the HeadList
> > which is a much shorter list of fields, replace your table with InvoiceHed
> > and also replace your datasetmode to DataSetMode.RowsDataSet
> > See if that helps.
> > *Jose C Gomez*
> > *Software Engineer*
> > *checkout my new blog <http://www.usdoingstuff.com> *
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > *Quis custodiet ipsos custodes?*
> > On Wed, May 23, 2012 at 10:51 AM, zanniebelle <rwatson@> wrote:
> > > Thanks John, but I originally tried that with the same results. I thought
> > > that because I wanted the list I'd need to use InvcHeadList as the table to
> > > use. InvoiceHeadList is a table (the only one) in the
> > > ARInvoice.ARInvoiceList dataset.
> > > I assumed that when you want to get a RowsDataSet it uses
> > > ARInvoiceData.InvcHead, where InvcHead should be used, but with a
> > > ListDataSet it would use ARInvoiceList.InvcHeadList.
> > > I just tested it again using InvcHead and got the same results...all the
> > > records are returned.
> > > Thanks again for the reply!
> > > --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > > > Change the 'InvcHeadList' to 'InvcHead' when you add the WC to the
> > > > hashtable.
> > > > You should be using the table name there. If you put something else in
> > > > there, Epicor looks for a table with that name, doesn't find anything and
> > > > your WC doesn't get applied.
> > > > On Wed, May 23, 2012 at 9:46 AM, zanniebelle <rwatson@> wrote:
> > > > > Hi All,
> > > > > I'm having a problem getting the whereclause to work when returning
> > > list
> > > > > records. I've tried the following two methods and both have no effect
> > > on
> > > > > the results returned i.e. all records are returned.
> > > > > Note when returning rows from InvcHead (DataSetMode.RowsDataSet) just
> > > the
> > > > > expected records are returned using the same where clause.
> > > > > // method 1
> > > > > String whereClause = "GroupID = 'GM123456' AND Posted = false";
> > > > > System.Collections.Hashtable wcHash = new
> > > System.Collections.Hashtable(1);
> > > > > wcHash.Add("InvcHeadList", whereClause);
> > > > > SearchOptions opts = SearchOptions.CreateRuntimeSearch(wcHash,
> > > > > DataSetMode.ListDataSet);
> > > > > _arInvoiceAdapter.InvokeSearch(opts);
> > > > > // method 2
> > > > > SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
> > > > > opts.NamedSearch.WhereClauses.Add("InvcHeadList", whereClause);
> > > > > bool morePages;
> > > > > DataSet lo_ds = _arInvoiceAdapter.GetList(opts, out morePages);
> > > > > Thanks in Advance!
> > > > > Ray
> > > > *John Driggers*
> > > > *High End Dev, System Design, Profit Drinking*
> > > > **:: 904.404.9233*
> > > > *:: waffqle@*
> > > > *:: NO FAXES*
> > > > [Non-text portions of this message have been removed]
