Help with Costing Workbench
Ephraim -
What version are you on? We're on 8.03.405 and all of our purchased parts are rev.-controlled and parts roll up without a problem. We use Cost Adjustment to assign costs to the standard-costed purchased parts and Costing Workbench to roll up the costs to the manufactured parts.
--- In vantage@yahoogroups.com, "efyf_1999" <effgroups@...> wrote:
> Thanks all for replying
> The real problem was that i created a revision on the purchased part and that really should not have a revision since the rollup considers every part with a revision as a manufactured part and rolls up the cost so if there is a revision without BOM it will set the cost to 0.
> So now i have to find a way how to record revisions for Purchased goods since we use it for the P/O to print the revision and details of the revision contained in the description.
> Ephraim Feldman
> Axis Lighting
> --- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@> wrote:
> > Do you have a BOM on PurchA? I usually only use view cost for parts with a BOM. I wouldn't think anything would load for a purchase part with no BOM.
> > To check costs, I go to part tracker (general->costs->retrieve). What cost is loaded for the average cost of PurchA? Does this same average cost value load for PurchA when you load details in costing workbench (costs->purchased parts->search->select all->ok)? How does this cost compare with the avg cost in part tracker?
> > You can manually adjust the costs in this screen and affect the final rollup cost for MfgB. So if it's not loading properly, you can manually update here just to get it done but should definitely follow up on this.
> > Other straws to grasp: Is the costing method for PurchA set at Average in both the part tab and the plant tab of the part master? I've seen some instances where the plant tab didn't update when the part tab was changed. Is PurchA set as inactive? There has to be something going on here.
> > Good luck,
> > Chris
> > --- In vantage@yahoogroups.com, "efyf_1999" <effgroups@> wrote:
> > > Hi All
> > > As i looked more into the problem i found some interesting things that maybe can shed light on the problem.
> > > Let me explain what i am working with.
> > > I have a part "PurchA" marked as purchased and costing as average.
> > > then i have part "MfgB" marked as manufacture and costing as standard.
> > > Part "MfgB" is using "PurchA" as BOM.
> > > I ran the costing workbench and loaded with filter part "MfgB" that automatically pulled "PurchA" into the workbench.
> > > Before doing anything else i went into the cost for purchased and selected part "PurchA" and selected "View Cost" from the menu, in the resulting window there is one line with the "PurchA" part and 0 cost in all columns, but in the bottom of the screen in the costs section the first 2 lines (for total cost and unit cost) are 0 and the third line for part cost has a value in material of 1.30 .
> > > Now when i look at the "View Cost" for part "MfgB" i see 2 lines one the asm line of the current part with 0 values then a line for the BOM mtl with the value of 1.30
> > > When i look at the bottom of the screen i see that in the lines of total cost and unit cost there is a valu of 1.30 but in the line cost the value is 0.
> > > Then i went to run the rollup and here is what happened.
> > > When i look at the view cost for the part "PurchA" everything is 0 even the line for part cost.
> > > When i look at the view cost for the part "MfgB" also everything is 0 the mtl line and all the bottom fields.
> > > So seems like something is reseting everything to 0 instead of updating the manufacture part.
> > > Would really appreciate any help
> > > Ephraim Feldman
> > > Axis Lighting
Im trying to to update the manufactured parts price by using the workbench so i ran it on all parts and loaded the cost based on costing method into the workbench.
When i ran the roll-up i noticed that alot of parts that are manufactured and the BOM parts do have a cost associated with dont get updated.
I went to a few and looked into the view costs and it showed me the right BOM but with no cost. when i acctually look up that part in the tracker i can see that it does have a cost to it but it doesnt get pulled.
A few parts did get updated but i have a lot that didnt .
Please help me on it since its a urgent matter.
Ephhraim Feldman
Axis Lighting
When updating a part with multilevel BOM, you only need to load details for the top level part. It will automatically pull the lower level subassemblies. When you roll, don't filter at all, just hit process and it should roll up all manufactured parts. Then check your Print Cost Set Group report and check the "Changed Items Only" box to view the results. If there are some parts not showing up, check the costing method for those parts to see if it's what you think it should be and compare with the costs for that method in part tracker.
So to summarized, the only things I can think of that would give zero cost after cost roll is the filter during the roll process and the costing methods.
HTH
Chris
> Thanks
> Ephhraim Feldman
> Axis Lighting
Good Day Ephraim:
Did you get any error messages when you ran it?
If lower levels cannot be rolled for some reason, then it will not
roll the next levels, although you may have a chance to override that
limitation with a prompt or a setting.
len.hartka@...
Of saab_barracuda
Sent: Tuesday, February 09, 2010 5:25 PM
Subject: [Vantage] Re: Help with Costing Workbench
costing methods.
HTH
Chris
updated.
pulled.
> Thanks
> Ephhraim Feldman
> Axis Lighting
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
I didnt get any error when rolling up
--- In vantage@yahoogroups.com, "Len Hartka" <len.hartka@...> wrote:
> Good Day Ephraim:
> len.hartka@...
> Of saab_barracuda
> costing methods.
> HTH
> Chris
> updated.
> pulled.
> > Thanks
> > Ephhraim Feldman
> > Axis Lighting
Thanks Chris for your reply
But i didnt apply any filtering and it still didnt update.
> HTH
> Chris
> > Thanks
> > Ephhraim Feldman
> > Axis Lighting
Hi All
Ephraim Feldman
Axis Lighting
> Thanks
> Ephhraim Feldman
> Axis Lighting
How about an inactive rev? There's a report for that as well.
Mark W.
Make sure the "mfg" part is really marked as Manufactured and not marked
Purchase in Part Maintenance.
We had mfg items marked as purchase and the BOM cost report would show a
zero dollar.
I'm only guessing that it could affect this as well.
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Mark Wonsil
Sent: Wednesday, February 10, 2010 3:35 PM
Subject: Re: [Vantage] Re: Help with Costing Workbench
costing methods.
Mark W.
Good luck,
Chris
> Hi All
> Ephraim Feldman
> Axis Lighting
And make sure the type code is purchased in the plant tab as well.
> zero dollar.
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
Ephraim Feldman
Axis Lighting
> Good luck,
> Chris
> > Hi All
> > Ephraim Feldman
> > Axis Lighting
