Help with CTE error: The multi-part identifier "PartMtl1.MtlPartNum" could not be bound
I’m hoping someone has seen this and fixed it?
I’m trying to work through the Ice tools CTE example and I’m facing this error? Here is the Query:
 * Disclaimer!!!
 * This is not a real query being executed, but a simplified version for general vision.
 * Executing it with any other tool may produce a different result.
with [SubQuery1] as
(select
	[PartMtl].[Company] as [PartMtl_Company],
	[PartMtl].[PartNum] as [PartMtl_PartNum],
	[PartMtl].[RevisionNum] as [PartMtl_RevisionNum],
	[PartMtl].[MtlSeq] as [PartMtl_MtlSeq],
	[PartMtl].[MtlPartNum] as [PartMtl_MtlPartNum],
	[PartMtl].[QtyPer] as [PartMtl_QtyPer],
	[PartMtl].[RelatedOperation] as [PartMtl_RelatedOperation],
	[PartMtl].[PullAsAsm] as [PartMtl_PullAsAsm],
	[PartMtl].[ViewAsAsm] as [PartMtl_ViewAsAsm],
	[PartMtl].[PlanAsAsm] as [PartMtl_PlanAsAsm],
	(0) as [Calculated_Hierarchy],
	(cast(substring('........',1,(Hierarchy + 1)) + PartMtl.MtlPartNum as nvarchar(25))) as [Calculated_Ind1]
from Erp.PartMtl as PartMtl
where (PartMtl.PartNum = @PartNum)
union all
select
	[PartMtl1].[Company] as [PartMtl1_Company],
	[PartMtl1].[PartNum] as [PartMtl1_PartNum],
	[PartMtl1].[RevisionNum] as [PartMtl1_RevisionNum],
	[PartMtl1].[MtlSeq] as [PartMtl1_MtlSeq],
	[PartMtl1].[MtlPartNum] as [PartMtl1_MtlPartNum],
	[PartMtl1].[QtyPer] as [PartMtl1_QtyPer],
	[PartMtl1].[RelatedOperation] as [PartMtl1_RelatedOperation],
	[PartMtl1].[PullAsAsm] as [PartMtl1_PullAsAsm],
	[PartMtl1].[ViewAsAsm] as [PartMtl1_ViewAsAsm],
	[PartMtl1].[PlanAsAsm] as [PartMtl1_PlanAsAsm],
	[SubQuery1].[Calculated_Hierarchy] as [Calculated_Hierarchy],
	[SubQuery1].[Calculated_Ind1] as [Calculated_Ind1]
from Erp.PartMtl as PartMtl1
inner join  SubQuery1  as SubQuery1 on
	PartMtl1.MtlPartNum = SubQuery1.PartMtl_MtlPartNum
	and PartMtl1.Company = SubQuery1.PartMtl_Company)
select
	[SubQuery11].[PartMtl_Company] as [PartMtl_Company],
	[SubQuery11].[PartMtl_PartNum] as [PartMtl_PartNum],
	[SubQuery11].[PartMtl_RevisionNum] as [PartMtl_RevisionNum],
	[SubQuery11].[PartMtl_MtlSeq] as [PartMtl_MtlSeq],
	[SubQuery11].[PartMtl_MtlPartNum] as [PartMtl_MtlPartNum],
	[SubQuery11].[PartMtl_QtyPer] as [PartMtl_QtyPer],
	[SubQuery11].[PartMtl_RelatedOperation] as [PartMtl_RelatedOperation],
	[SubQuery11].[PartMtl_PullAsAsm] as [PartMtl_PullAsAsm],
	[SubQuery11].[PartMtl_ViewAsAsm] as [PartMtl_ViewAsAsm],
	[SubQuery11].[PartMtl_PlanAsAsm] as [PartMtl_PlanAsAsm],
	(Calculated_Hierarchy + 1) as [Calculated_Hierarchy2],
	(cast ( substring('........',1 ,(Hierarchy2 + 1) ) + PartMtl1.MtlPartNum as nvarchar(25))) as [Calculated_Ind2]
from  SubQuery1  as SubQuery11
In your cast at the end, did you try PartMtl.MtlPartNum instead?
I tried that and the error just reverted to unable to bind PartMtl? So no joy there.
I think it might be this. You should be joining the Material from the first query to the Part on the second query.
I recreated the query and it now works. Ghost in the machine! lol.
