Help with simply customizations
Hi, I'm pretty sure that Inspection Required is set at the Part
Class, Supplier, or PO. The hierarchy should follow this logic also.
So if you are not using part classes your next setting would be at
the supplier maintenance.
Kathleen
--- In vantage@yahoogroups.com, "kirsty2179" <dobby01@...> wrote:
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
> wrote:
> > Why don't you use the native inspection required checkbox? (What
> version are you on?)
> > Rob
> > --- On Tue, 1/27/09, kirsty2179 <dobby01@> wrote:
> > From: kirsty2179 <dobby01@>
> > Subject: [Vantage] Help with simply customizations
> > Date: Tuesday, January 27, 2009, 8:28 AM
> > Hi Im on version 803.407
> thnaks
> > Hello,
> > Can anyone help
> > Have created inspection rqy in part maintenance setup as
> checkbox01
> > this hold,s ticked after saving, Now i,m trying to pull this
into
> po
> > entry but it will not pull tick in po lines ? Any help would be
> great
Hello,
Can anyone help
Have created inspection rqy in part maintenance setup as checkbox01
this hold,s ticked after saving, Now i,m trying to pull this into po
entry but it will not pull tick in po lines ? Any help would be great
Why don't you use the native inspection required checkbox? (What version are you on?)
Rob
Hello,
Can anyone help
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
> Rob
> From: kirsty2179 <dobby01@...>
thnaks
> Hello,
> Can anyone help
checkbox01
po
great
