Hi,
Thanks to Jose and Joshua, I was able to get what I needed so I am posting the additional steps I took.
1. Create a customization as any other in Full Epicor.
2. Create a new menu item under Material Handling within the Handheld area named Count Entry - Custom, menu id is UDCECust
3. mi.Invoke(oTrans, New Object() {0, 5, "Cust", "MNU01"}) - changed to mi.Invoke(oTrans, New Object() {8,3, " "Count Entry - Custom","UDHHCE"})
***8 is used for the Inventory process menu - you will find the vanilla Count Entry is 8,1...The second number shows where it will be in the list - in this case 1 will be second item in list
- the index which starts with 0, so the 3 index I used means it will be 4th on the list...***
4. Add a new menu item with this customization name is Handheld Menu - menu id is UDHHC.
5. Add a process calling to process reference Epicor.Mfg.Menu.Handheld with menu ID UDHHC
6. Add a sub process for process UDHHCE that has the customization applied (my custom code for Count Entry - Custom)
***This does not have to match step 2, but must match step 3 menu ID***
7. Add this tag in the config file for mfgsys - <HHCustomMenuID value="UDHHC" /> (I put mine under <MESCustomMenuID value=" " />)
The result is that I now have custom menu list under Inventory Process on the Handheld that shows 1-Adj Inventory, 2 - Count Entry, 3 - Move Inventory, 4 - Count Entry - Custom (which brings up a custom menu for count entry). We wanted to have both the vanilla and a custom menu for Count Entry.
Still yet to test on the actual handheld device, but the shortcuts seem to work as needed now.
Thanks again group!
Karen
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, May 21, 2013 8:26 AM
To: Vantage
Subject: Re: [Vantage] HH - add menu item to lstMenuItems
Hi Karen,
I just tested this on my 8.03 Just put this code on Form Load,fcourse replace "Cust" with whatever string you want to see on the menu and MNU01 with your menu ID
Dim mi As MethodInfo =
GetType(Epicor.Mfg.UI.Menu.Handheld.Transaction).GetMethod("addMenuItem",
(BindingFlags.NonPublic Or BindingFlags.Instance), Nothing, New Type() {GetType(System.Int32), GetType(System.Int32), GetType(String), GetType(String)}, Nothing)
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
<http://www.usdoingstuff.com>
Thanks again group!
Karen
To: Vantage
Hi Karen,
*Jose C Gomez*
*Software Engineer*
On Tue, May 21, 2013 at 9:01 AM, Karen Schoenung < kschoenung@...<mailto:kschoenung@...>> wrote:
> Yes, 8.03.409C (SQL)
> From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On
> Sent: Monday, May 20, 2013 6:18 PM
> To: Vantage
> Subject: RE: [Vantage] HH - add menu item to lstMenuItems
> what version? 8?
> On May 20, 2013 5:25 PM, "Karen Schoenung"
> <kschoenung@...<mailto:kschoenung@...>>
> wrote:
> > Hi Jose,
> > Below is the converted code which compiles successfully - but then
> > throws the error shown when trying to use the customization (so far
> > doing this in the full Epicor, Handheld menu, customizing the form
> > load screen that has the first 5 menu items listed...Any ideas?
> > Thanks,
> > Karen
> > Private Sub HHMenuForm_Load(ByVal sender As object, ByVal args As
> > EventArgs) Handles HHMenuForm.Load
> > '// Add Event Handler Code
> > te m", BindingFlags.NonPublic Or BindingFlags.Instance, Nothing, New
> > Type() {GetType(Integer), GetType(Integer), GetType([String]),
> > GetType([String])},
> > Nothing)
> > mi.Invoke(oTrans, New Object() {0, 5, "Cust", "HHMN1010"})
> > '//LoadMenuItems()
> > Dim ExampleFormClass As Object
> > '//Dim ExampleFormClass As New HHMenuForm
> > If True Then
> > ExampleFormClass.addMenuItem(0, 0,
> > EpiString.GetString("menuInquiries"),
> > "MENU01")
> > ExampleFormClass.addMenuItem(0, 1, EpiString.GetString("menuLabor"),
> > "MENU02")
> > ExampleFormClass.addMenuItem(0, 2,
> > EpiString.GetString("menuMaterial"),
> > "MENU03")
> > ExampleFormClass.addMenuItem(0, 3,
> > EpiString.GetString("menuShipRcv"),
> > "MENU04")
> > ExampleFormClass.addMenuItem(0, 4,
> > EpiString.GetString("menuProduction"),
> > "MENU06")
> > ExampleFormClass.addMenuItem(1, 0,
> > EpiString.GetString("menuBinTracker"),
> > "HHMN1001")
> > ExampleFormClass.addMenuItem(1, 1,
> > EpiString.GetString("menuLotTracker"),
> > "HHMN1002")
> > ExampleFormClass.addMenuItem(1, 2,
> > EpiString.GetString("menuPartTracker"),
> > "HHMN1003")
> > ExampleFormClass.addMenuItem(1, 3,
> > EpiString.GetString("menuSerialTracker"), "HHMN1004")
> > ExampleFormClass.addMenuItem(1, 4,
> > EpiString.GetString("menuTransLog"),
> > "HHMN1005")
> > ExampleFormClass.addMenuItem(2, 0,
> > EpiString.GetString("menuClockIn"),
> > "HHMN3001")
> > ExampleFormClass.addMenuItem(2, 1,
> > EpiString.GetString("menuStartIndirect"), "HHMN3002")
> > ExampleFormClass.addMenuItem(2, 2,
> > EpiString.GetString("menuStartProduction"), "HHMN3003", "P")
> > ExampleFormClass.addMenuItem(2, 3,
> > EpiString.GetString("menuStartSetup"),
> > "HHMN3004", "P")
> > ExampleFormClass.addMenuItem(2, 4,
> > EpiString.GetString("menuStartRework"),
> > "HHMN3005", "P")
> > ExampleFormClass.addMenuItem(2, 5,
> > EpiString.GetString("menuWorkQueue"),
> > "HHMN3006")
> > ExampleFormClass.addMenuItem(3, 0,
> > EpiString.GetString("menuInbound"),
> > "MENU07")
> > ExampleFormClass.addMenuItem(3, 1,
> > EpiString.GetString("menuInventory"),
> > "MENU08")
> > ExampleFormClass.addMenuItem(3, 2,
> > EpiString.GetString("menuOutbound"),
> > "MENU09")
> > ExampleFormClass.addMenuItem(3, 3,
> > EpiString.GetString("menuMaterialQueueEdit"), "HHMN2001", "M")
> > ExampleFormClass.addMenuItem(3, 4,
> > EpiString.GetString("menuMaterialQueue"), "HHMN2002", "M")
> > ExampleFormClass.addMenuItem(3, 5,
> > EpiString.GetString("menuMaterialIDQueue"), "HHMN2019", "M")
> > ExampleFormClass.addMenuItem(3, 6,
> > EpiString.GetString("menuAutoSelectTrans"), "HHMN2020", "M")
> > ExampleFormClass.addMenuItem(3, 7,
> > EpiString.GetString("menuUOMSplitMerge"), "HHMN2013", "M")
> > ExampleFormClass.addMenuItem(4, 0,
> > "MENU10")
> > ExampleFormClass.addMenuItem(4, 1,
> > "MENU11")
> > ExampleFormClass.addMenuItem(6, 0,
> > EpiString.GetString("menuKanbanReceipts"), "HHMN6001", "P")
> > ExampleFormClass.addMenuItem(7, 0,
> > EpiString.GetString("menuJobReceiptToInv"), "HHMN2003", "M")
> > ExampleFormClass.addMenuItem(7, 1,
> > EpiString.GetString("menuJobReceiptToJob"), "HHMN2004", "M")
> > ExampleFormClass.addMenuItem(7, 2,
> > EpiString.GetString("menuJobReceiptToSalvage"), "HHMN2005", "M")
> > ExampleFormClass.addMenuItem(7, 3,
> > EpiString.GetString("menuReturnAssembly"), "HHMN2006", "M")
> > ExampleFormClass.addMenuItem(7, 4,
> > EpiString.GetString("menuReturnMaterial"), "HHMN2007", "M")
> > ExampleFormClass.addMenuItem(8, 0,
> > EpiString.GetString("menuAdjustInventory"), "HHMN2008", "M")
> > ExampleFormClass.addMenuItem(8, 1,
> > EpiString.GetString("menuCountEntry"),
> > "HHMN2009", "M")
> > ExampleFormClass.addMenuItem(8, 2,
> > EpiString.GetString("menuMoveInventory"), "HHMN2010", "M")
> > ExampleFormClass.addMenuItem(8, 3,
> > EpiString.GetString("menuUnpickSalesOrder"), "HHMN2040", "M")
> > ExampleFormClass.addMenuItem(8, 4,
> > EpiString.GetString("menuUnpickTransOrder"), "HHMN2041", "M")
> > ExampleFormClass.addMenuItem(9, 0,
> > EpiString.GetString("menuIssueAssembly"), "HHMN2011", "M")
> > ExampleFormClass.addMenuItem(9, 1,
> > EpiString.GetString("menuIssueMaterial"), "HHMN2012", "M")
> > ExampleFormClass.addMenuItem(10, 0,
> > EpiString.GetString("menuContainerArrival"), "HHMN4020", "R")
> > ExampleFormClass.addMenuItem(10, 1,
> > EpiString.GetString("menuContainerReceipts"), "HHMN4021", "R")
> > ExampleFormClass.addMenuItem(10, 2,
> > EpiString.GetString("menuICReceipts"),
> > "HHMN4007", "R")
> > ExampleFormClass.addMenuItem(10, 3,
> > EpiString.GetString("menuPOReceipts"),
> > "HHMN4001", "R")
> > ExampleFormClass.addMenuItem(10, 4,
> > EpiString.GetString("menuTOReceipts"),
> > "HHMN4005", "R")
> > ExampleFormClass.addMenuItem(11, 0,
> > EpiString.GetString("menuConfirmShipExampleFormClassnts"),
> > "HHMN4002",
> > "R") ExampleFormClass.addMenuItem(11, 1,
> > EpiString.GetString("menuMasterpack"),
> > "HHMN4010", "R")
> > ExampleFormClass.addMenuItem(11, 2,
> > EpiString.GetString("menuMiscShipment"), "HHMN4009", "R")
> > ExampleFormClass.addMenuItem(11, 3,
> > EpiString.GetString("menuSubcontractShipment"), "HHMN4008", "R")
> > ExampleFormClass.addMenuItem(11, 4,
> > EpiString.GetString("menuCustomerMassShip"), "HHMN4004", "R")
> > ExampleFormClass.addMenuItem(11, 5,
> > EpiString.GetString("menuPickedOrders"), "HHMN4003", "R")
> > ExampleFormClass.addMenuItem(11, 6,
> > EpiString.GetString("menuTOShipment"),
> > "HHMN4006", "R")
> > ExampleFormClass.addMenuItem(11, 7,
> > EpiString.GetString("menuPackout"),
> > "HHMN4011", "R")
> > End If
> > End Sub
> > Error Detail
> > Exception has been thrown by the target of an invocation.
> > Stack Trace
> > at System.RuntimeMethodHandle._InvokeMethodFast(Object target,
> > Object[] arguments, SignatureStruct& sig, MethodAttributes
> > methodAttributes, RuntimeTypeHandle typeOwner) at
> > System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[]
> > arguments, Signature sig, MethodAttributes methodAttributes,
> > System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags
> > invokeAttr, Binder binder, Object[] parameters, CultureInfo culture,
> > Boolean skipVisibilityChecks) at
> > invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
> > at
> > Epicor.Mfg.UI.Customization.CustomScriptManager.OnCustomCodeFormLoad
> > (O
> > bject
> > sender, EventArgs e)
> > Inner Exception
> > Object variable or With block variable not set.
> > Inner Stack Trace
> > at
> > Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Objec
> > t
> > Instance)
> > at
> > Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Objec
> > t Instance, Type Type, String MemberName, Object[] Arguments,
> > String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack,
> > Boolean
> > IgnoreReturn)
> > at Script.HHMenuForm_Load(Object sender, EventArgs args)
> > Sent: Monday, May 20, 2013 10:53 AM
> > To: Vantage
> > Hi Karen
> > You have to put it in the Customization for the Main Form for the
> > hand Held Screen. You can do it on Form Load or Initialize. Letme
> > know if you have any other questions.
> > *Jose C Gomez*
> > *Software Engineer*
> > On Mon, May 20, 2013 at 11:50 AM, Karen Schoenung <
> > > Hi,
> > > I searched and found Jose's post about using reflection to add a
> > > menu item
> > > - but I am not sure where to put the code. Would this be put in
> > > the first form that opens with menu items listed? Do I need to put
> > > this in the script editor? Of course some changes would be needed
> > > to convert to vb and Vantage 8.03.409c...Any additional
> > > information someone can provide? I thought it would be pretty easy
> > > to add a menu item to
> > handhelds, but I guess not...
> > > Here is the code Jose had for another message posted (to add Sales
> > > Order Pick List):
> > > using System.Reflection
> > > MethodInfo mi =
> > > typeof(Epicor.Mfg.UI.Menu.Handheld.Transaction).GetMethod("addMenu
> > > It
> > > em
> > > ",BindingF\
> > > lags.NonPublic
> > > | BindingFlags.Instance, null, new
> > > Type[]{typeof(int),typeof(int),typeof(String),typeof(String)},null
> > > ); mi.Invoke(oTrans,new object[]{0,5,"Cust","HHMN1010"});
> > > Where 0 and 5 are the indexes of where you'd like to put the menu
> > > based off the currently available menus' below (9.05.607B) this
> > > list will be different based on your version and patch level,
> > > since our beloeved Epicor decided that using a regular menu system
> > > they already had built was out of the question and they simply
> > > hard coded
> as shown.
> > > public void LoadMenuItems()
> > > this.addMenuItem(0, 0, EpiString.GetString("menuInquiries"),
> > > "MENU01"); this.addMenuItem(0, 1,
> > > EpiString.GetString("menuLabor"), "MENU02"); this.addMenuItem(0,
> > > 2, EpiString.GetString("menuMaterial"),
> > > "MENU03"); this.addMenuItem(0, 3,
> > > "MENU04"); this.addMenuItem(0, 4,
> > > EpiString.GetString("menuProduction"), "MENU06");
> > > this.addMenuItem(1, 0, EpiString.GetString("menuBinTracker"),
> > > "HHMN1001"); this.addMenuItem(1, 1,
> > > "HHMN1002"); this.addMenuItem(1, 2,
> > > EpiString.GetString("menuPartTracker"), "HHMN1003");
> > > this.addMenuItem(1, 3, EpiString.GetString("menuSerialTracker"),
> > > "HHMN1004");
> > > this.addMenuItem(1, 4, EpiString.GetString("menuTransLog"),
> > > "HHMN1005"); this.addMenuItem(2, 0,
> > > EpiString.GetString("menuClockIn"), "HHMN3001");
> > > this.addMenuItem(2, 1, EpiString.GetString("menuStartIndirect"),
> > > "HHMN3002");
> > > this.addMenuItem(2, 2, EpiString.GetString("menuStartProduction"),
> > > "HHMN3003", "P");
> > > this.addMenuItem(2, 3, EpiString.GetString("menuStartSetup"),
> > > "HHMN3004", "P");
> > > this.addMenuItem(2, 4, EpiString.GetString("menuStartRework"),
> > > "HHMN3005", "P");
> > > this.addMenuItem(2, 5, EpiString.GetString("menuWorkQueue"),
> > > "HHMN3006"); this.addMenuItem(3, 0,
> > > EpiString.GetString("menuInbound"), "MENU07"); this.addMenuItem(3,
> > > 1, EpiString.GetString("menuInventory"), "MENU08");
> > > this.addMenuItem(3, 2, EpiString.GetString("menuOutbound"),
> > > "MENU09"); this.addMenuItem(3, 3,
> > > EpiString.GetString("menuMaterialQueueEdit"), "HHMN2001", "M");
> > > this.addMenuItem(3, 4, EpiString.GetString("menuMaterialQueue"),
> > > "HHMN2002", "M");
> > > this.addMenuItem(3, 5, EpiString.GetString("menuMaterialIDQueue"),
> > > "HHMN2019", "M");
> > > this.addMenuItem(3, 6, EpiString.GetString("menuAutoSelectTrans"),
> > > "HHMN2020", "M");
> > > this.addMenuItem(3, 7, EpiString.GetString("menuUOMSplitMerge"),
> > > "HHMN2013", "M");
> > > this.addMenuItem(4, 0, EpiString.GetString("menuInbound"),
> > > "MENU10"); this.addMenuItem(4, 1,
> > > EpiString.GetString("menuOutbound"), "MENU11");
> > > this.addMenuItem(6, 0, EpiString.GetString("menuKanbanReceipts"),
> > > "HHMN6001", "P");
> > > this.addMenuItem(7, 0, EpiString.GetString("menuJobReceiptToInv"),
> > > "HHMN2003", "M");
> > > this.addMenuItem(7, 1, EpiString.GetString("menuJobReceiptToJob"),
> > > "HHMN2004", "M");
> > > this.addMenuItem(7, 2,
> > > EpiString.GetString("menuJobReceiptToSalvage"), "HHMN2005", "M");
> > > this.addMenuItem(7, 3, EpiString.GetString("menuReturnAssembly"),
> > > "HHMN2006", "M");
> > > this.addMenuItem(7, 4, EpiString.GetString("menuReturnMaterial"),
> > > "HHMN2007", "M");
> > > this.addMenuItem(8, 0, EpiString.GetString("menuAdjustInventory"),
> > > "HHMN2008", "M");
> > > this.addMenuItem(8, 1, EpiString.GetString("menuCountEntry"),
> > > "HHMN2009", "M");
> > > this.addMenuItem(8, 2, EpiString.GetString("menuMoveInventory"),
> > > "HHMN2010", "M");
> > > this.addMenuItem(8, 3,
> > > EpiString.GetString("menuUnpickSalesOrder"), "HHMN2040", "M");
> > > this.addMenuItem(8, 4,
> > > "HHMN2041", "M"); this.addMenuItem(9, 0,
> > > "HHMN2011", "M");
> > > this.addMenuItem(9, 1, EpiString.GetString("menuIssueMaterial"),
> > > "HHMN2012", "M");
> > > this.addMenuItem(10, 0,
> > > EpiString.GetString("menuContainerArrival"), "HHMN4020", "R");
> > > this.addMenuItem(10, 1,
> > > "HHMN4021", "R"); this.addMenuItem(10, 2,
> > > "HHMN4007", "R");
> > > this.addMenuItem(10, 3, EpiString.GetString("menuPOReceipts"),
> > > "HHMN4001", "R");
> > > this.addMenuItem(10, 4, EpiString.GetString("menuTOReceipts"),
> > > "HHMN4005", "R");
> > > this.addMenuItem(11, 0,
> > > EpiString.GetString("menuConfirmShipments"), "HHMN4002", "R");
> > > this.addMenuItem(11, 1, EpiString.GetString("menuMasterpack"),
> > > "HHMN4010", "R");
> > > this.addMenuItem(11, 2, EpiString.GetString("menuMiscShipment"),
> > > "HHMN4009", "R");
> > > this.addMenuItem(11, 3,
> > > EpiString.GetString("menuSubcontractShipment"), "HHMN4008", "R");
> > > this.addMenuItem(11, 4,
> > > "HHMN4004", "R"); this.addMenuItem(11, 5,
> > > "HHMN4003", "R");
> > > this.addMenuItem(11, 6, EpiString.GetString("menuTOShipment"),
> > > "HHMN4006", "R");
> > > this.addMenuItem(11, 7, EpiString.GetString("menuPackout"),
> > > "HHMN4011", "R");
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder
Individual Email | Traditional
http://groups.yahoo.com/group/vantage/join
(Yahoo! ID required)
vantage-digest@yahoogroups.com<mailto:vantage-digest@yahoogroups.com>
vantage-fullfeatured@yahoogroups.com<mailto:vantage-fullfeatured@yahoogroups.com>
vantage-unsubscribe@yahoogroups.com<mailto:vantage-unsubscribe@yahoogroups.com>
http://docs.yahoo.com/info/terms/
