Holiday Hours not showing up
Yep, found that section as well... It looks fine...
> Your 'Holiday' pay type must also be set up correctly.
> -----Original Message-----
> From: Paul Siebers [mailto:paul.siebers@...]
> A while ago I entered my holiday hours in the Holiday section of the
> maintenance file maintenance section under Payroll. None of
> the employees
> has been credited with the 8 hours holiday pay they should
> have received. I
> have completed every field of the Holiday section correctly, what am I
> missing?
> We no longer allow attachments to files. To access/share
> Report Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you
> try it, go to www.egroups.com, login and be sure to save your
> password, choose My Groups, choose Vantage, then choose
> Files. If you save the password, the link above will work
> the next time you try it.)
Hello all,
maintenance file maintenance section under Payroll. None of the employees
has been credited with the 8 hours holiday pay they should have received. I
missing?
TIA,
Paul M. Siebers
missing?
